2005 Taco LED Gauge MOD!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airfce250, Jul 25, 2011.
  1. Jul 25, 2011 at 6:45 PM
    airfce250
    airfce250 [OP] Active Member
    Cory
    2013 Tacoma TRD Sport
    Today i got the LEDs in to mod the gauges. I screwed up and bought the leds on ebay... I will never buy off there again. I was supposed to get 19 leds for the mod. I only got 13, i immediately messaged the sell and supposedly the correct amount are on the way after much deliberation. I HATE EBAY!!! if you are looking to do this mod just order the leds from an electronic store online! So i figured i would at least start the mod, well what i could do with what i had. after 3 HR of swapping led and finding that over half the leds i got in the kit were bad i only got half way done. needless to say im not to happy about the whole situation. But leaned a valuable lessen! Although i an supper stocked about the fuel and temp gauges!
    Here a pic let me know what yall think
    i know the speedometer is blue, purple, pink, orange. all due to the fact i ran out of good blue ones. and could only change one.
    Respectfully
    Cory
    2005 Pre Runner
  2. Jul 25, 2011 at 6:47 PM
    TheTacoTruck
    TheTacoTruck Well-Known Member
    Scott
    Central PA
    05 TRD 6-Spd
    Fuel and temp gauges are looking good, Good luck with the rest!
  3. Jul 25, 2011 at 6:48 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  4. Jul 25, 2011 at 6:51 PM
    airfce250
    Cory
    Thanks man just what I needed
  5. Aug 4, 2011 at 7:52 PM
    airfce250
    Cory
    DONE FINALY
  6. Aug 4, 2011 at 7:56 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Looks awesome, dude!
    Fink
  7. Aug 9, 2011 at 2:38 PM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    few questions about this because I want to do the same thing..
    1. do you have much electrical experience?
    2. was it hard to get to the leds?
    3. about how much did the lights cost and all you needed was lights... no special wires or added things other then the stock harnesses?
    thanks for doing this mod too. :cool:
  8. Aug 9, 2011 at 2:46 PM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    Is this as simple as changing the LEDs out with existing hardware?
    Personally, I'd like the gauges to match the hue of the devices in the center stack.
  9. Aug 9, 2011 at 2:52 PM
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    x2 + how much of a pain is it to solder in the led's
  10. Aug 9, 2011 at 2:54 PM
    Sabre
    Sabre Well-Known Member
    Kyle
    Silverdale, WA
    2014 F-150 FX4
    there is alot of people in socal who do gauge swaps for people
  11. Aug 9, 2011 at 3:04 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 36" TSLs , 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    its not hard at all to solder! all you need is tha gun and some solder! Solder is very maluable so it melts instantly when you touch it with a gun. Use tweezers to pick up the bulbs and put tha new ones in! And yes all you need is bulbs unless you wanna change the needle colors too! The leds are the easier part of the swap! I think it took me longer to take it apart and put it back together then to actually change the lights! Im an electrician but it has nothing to do with electrical work! This is very easy to do urself!
    heres mine
  12. Aug 9, 2011 at 3:17 PM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    What size LED's are used in this swap? Is there a voltage rating I need to look for? I've been thinking about sending mine out but if I am able to do it myself (I can solder fairly proficiently) I'd rather not have the turnaround time with the mail exchange.
  13. Aug 9, 2011 at 4:02 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    http://www.oznium.com/plcc-2
    those are all you need! Once i figured out the easiest way to take apart the cluster it only took me about an hour to do the whole thing including the needles! You can do it urself, i promise! Once you get the cluster apart and locate the LEDS and do a few of them you'll be like " damn this isnt hard at all"
  14. Aug 9, 2011 at 7:05 PM
    ST3VE
    MD --> SC
    Very informative. Your work is very great!
    About how many LEDS will you need?
  15. Aug 9, 2011 at 7:08 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    thats the way i want mine but with white needles
  16. Aug 9, 2011 at 7:08 PM
    pollock21
    pollock21 Well-Known Member
    Brian
    Cornelius, NC
    '11 Tacoma DC, TRD Sport 4x4
    Did anyone else notice the email of one of the contacts? Puma Suede, she's a porn star if you don't know. LOL
  17. Aug 9, 2011 at 7:18 PM
    MarinePhoenix2207
    MarinePhoenix2207 Well-Known Member
    South Jersey (yes, there's a North and South)
    09 Double Cab TRD sport
    bug/debris deflector, hose clamp mod, G4 elite fold-a-cover, Westin black nerf bars, Weathertech floor mats, 285/70/17 Goodyear Wrangler Duratracs, MO951 black Moto Metals 17x9, Pop n' Lock w b/u camera, "TRD" third brake light mod, 13" black FA-series antenna, 20% front 5% rear tint, painted badges mod, rear diff breather mod, Thule 400xt Aero roof rack, Westin Sportsman black grille guard, silver pinstripe removed, Tacoma short bed bedmat, 3" Toytec Bilstein adjustable lift kit w 5100 shocks and 2" lift AAL, Redline Tuning Quicklift Plus, Rockford Fosgate sound system w/ Kenwood h/u
    any pics of the actual install?
  18. Aug 10, 2011 at 6:54 PM
    airfce250
    Cory
    1. im an avionics technician, 6 years electrical experience
    2. no easy as ordering them online
    3. i believe they are .49 each. i needed 12
  19. Aug 10, 2011 at 7:02 PM
    airfce250
    Cory
    if you are thinking about doing this mod just remember the phasing and a few other things. when you look at your old leds you will notice one corner notched out. there is a reason for this. LEDs only work in one direction of. Change them out one by one and always look at the phasing. if you are new to soldering change out one at a time and check it to see if it works. just plug it in. the leds also run in series so if you didnt get a good connection/ phased wrong/ or bad led you will know.
    good luck!!!
  20. Aug 10, 2011 at 7:34 PM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    man that looks awesome. i want thisssssss.
