2005 tacoma 2nd gen terminal frame rot rust cancer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomeontherange, Dec 14, 2012.
  1. Dec 15, 2012 at 2:48 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    I need to check mine.
  2. Dec 15, 2012 at 2:54 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Damn!
    Good luck OP.
  3. Dec 15, 2012 at 11:55 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Good luck, hopefully toyota will do the right thing. That much rust is unacceptable for a truck of that age...
  4. Dec 15, 2012 at 12:09 PM
    jandrews
    '09 FourDubDee TRD OR
    Impressive.
    I'm anal about frame maintenance, and living in the southeast helps. My truck should last until Jesus comes back. That said, my sympathies, hope ToMoCo makes it right.
  5. Dec 15, 2012 at 12:13 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    7 year corrosion warranty should help here , no ?
    That sucks OP
  6. Dec 15, 2012 at 12:43 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    If it is an 05 it was likely sold in 04 so it is past the 7 year warranty.
    I am guessing you will be told to fly a kite, unfortunately.
    Toyota is not what it used to be. They test frames for this and sell them knowing this based on the coating or lack there of that they use.
  7. Dec 16, 2012 at 5:35 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    After seeing this, I did what I had been putting off for a few weeks. Applied three cans of COR Ban
    http://www.zipchem.com/products/product_detail.aspx?id=NjY=
    While not open like most of the frame, there are a lot of openings and ways to spray the internal box structure. I also fogged the internal area from the open end of the box at the rear.
    One place I was surprised had water coming flowing out while applying the Cor Ban was well aft of the box area where a frame crossmember ties into the frame rail. There is also a frame doubler that could easily corrode also between the main frame rail and doubler.
    PK
  8. Dec 16, 2012 at 6:14 AM
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    I think Toyota will take care of you
  9. Dec 17, 2012 at 8:47 AM
    Syncros
    Syncros Well-Known Member
    My 82 4wd Pickup looks that, but its seen 30 years of salty winters, the frame was full of mud/salt/water when I cut it apart to scrap it.
    I'm guessing yours was driven on the beach a lot and never washed.
  10. Dec 17, 2012 at 2:43 PM
    tacomeontherange
    tacomeontherange [OP] this ain't no picnic
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    People out sick today so no news yet.
    Am trying to line up a lawyer so that we are fully informed about our rights and options.
  11. Dec 17, 2012 at 3:41 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    Toyota is #10 on the global fortune 500 list and you cannot find answers due to someone being sick, pretty sad.
  12. Dec 17, 2012 at 4:02 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yep Toyota knows its a problem again. There are trucks even with rot bigger then what OP has. Its insane that they did not protect frame after what they went with 1gens. New Frames I guess
  13. Dec 17, 2012 at 5:01 PM
    tacomeontherange
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    It's the local person who's out sick right now, so I'm not pointing the finger at corporate; just letting thread followers know that there won't be any news today.
  14. Dec 17, 2012 at 5:10 PM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    This thread makes me nervous. I have some surface rust on my frame. I lightly sanded and hit it with rustoleum rattle can, but that wont hold up in the salt and winters we get. I should get an estimate from Zeibart to see what they would charge. I know there is a local Krown dealer now too, that would be a yearly deal though. hrm
  15. Dec 17, 2012 at 5:14 PM
    #35
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Don't forget that the buyback didn't start until only a few years ago (I honestly don't recall the specific year), so even if Toyota did implement a solution on the later 2nd gens, those wouldn't have shown up until at least 1-2 years after the recall.
    I do, too, hope that Toyota steps up on the 2nd gen trucks (especially being an owner in the Northeast) in terms of extended warranty similar to the 95-04 models, or replacement/buyback when the time comes.
    Until them, I'll keep coating and hoping for the best.
  16. Dec 17, 2012 at 5:29 PM
    #36
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    I am interested in what Toyota says..
  17. Dec 17, 2012 at 5:34 PM
    #37
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    sub'd - You'd think Toyota would have figured this out first time around.
  18. Dec 17, 2012 at 5:35 PM
    #38
    speeddemon2588
    speeddemon2588 Well-Known Member
    Andres
    Columbus, IN
    08 TRD Rugged Trail
    5100's
    I paid about 280 for the full package. Greatest thing I ever did.
  19. Dec 17, 2012 at 5:40 PM
    #39
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
  20. Dec 17, 2012 at 6:01 PM
    #40
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    I think they'll take care of you They know that people talk about this kind of stuff.
