2005 tacoma 2nd gen terminal frame rot rust cancer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomeontherange, Dec 14, 2012.
  1. Jul 21, 2015 at 1:13 PM
    #621
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Not to be a negative-nancy but the option for a loaner vehicle is courtesy by the dealership, they don't HAVE to offer one. And the time withour your truck, nor do they owe you anything for that. You bought it, like so many of us, and found the construction/materials to be, well, shitty. Look at the bright side, Toyota is footing the bill to replace the frames on how many vehicles? Anyone have a tally from across North America? Doesn't matter, you got a refund for the LCA's and a new frame. Go enjoy you almost new truck and be happy.
    Im at 145 days and counting, btw. But I just recieved a call that my frame is in, waiting for other parts.
    Jake1530 likes this.
  2. Jul 21, 2015 at 5:00 PM
    #622
    tacomeontherange
    tacomeontherange [OP] this ain't no picnic
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    cool story bro.
  3. Jul 21, 2015 at 5:02 PM
    #623
    tacomeontherange
    central KY
    05 SR5 tacoma TRD
    large hole in frame
    Go on... LOL
    truck has been sold, a while ago. I'm rockin the pleiades these days. I miss a truck bed from time to time. will probably buy a beater.
  4. Jul 22, 2015 at 8:10 AM
    #624
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    so you got the new frame and stuff after all the waiting and just sold it? Makes sense.
  5. Jul 22, 2015 at 8:42 AM
    #625
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    My frame came in as well the other day. Wonder how long the rest will take?
  6. Jul 22, 2015 at 11:41 AM
    #626
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    They must have gotten a big shipment because mine came in also, its been 6 months. As expected the front calipers are locked up. They wanted $600 a piece to replace them. I got reman for $88 each that they are going to swap in.
  7. Jul 23, 2015 at 1:12 PM
    #627
    81shark
    81shark Well-Known Member
    why did they lock up... from non use. toyota should be replacing them.
  8. Jul 23, 2015 at 5:26 PM
    #628
    offgrid taco
    ned
    mass
    Yes from non use. A bunch of people are having this same problem. Toyota will not pay for them. I tried but no love. People also have rusted rotors and flat spotted tires. None of it is covered. If you have the option to drive your truck while waiting for the frame to come in I would recommend it. Mine was deemed unsafe to drive so I had no choice.
  9. Jul 24, 2015 at 1:03 PM
    #629
    rpktaco
    rpktaco Well-Known Member
    nj
    05 sr5 trd
    had mine done a couple of problems i found was power steering pump was leaking pump fitting said might need a new hose but that would not be covered, transfer case is leaking at drive shaft they will cover that, 1 bolt that holds sway arm to frame was not welding in at factory i guess ? they put a mickey mouse nut and bolt in will check with them, all the caps for the bleeder screws missing, they reuse all plastic clips even if broken, broke the tip of my rear shock, took my spare tire lock. i guess the real pain is dealing with the dealer after you pick up you truck. overall they did a good job but never recommend to replace anything while change the frame guess when they start they don't feel like stopping to ask.dealer saying it's a 10 year old truck things leak i said wasn't leaking when i brought it in.
  10. Jul 24, 2015 at 5:16 PM
    #630
    offgrid taco
    ned
    mass
    Got mine back today. It feels like they did a good job. Runs well tracks straight and true. No vibrations or squeeks. One big problem though. They broke the shifter on my manual transmission. I remember the day I dropped it off and the lot attendant said there seemed to be a problem with the truck, he couldnt find reverse. My guess is he had never driven a truck with the TRD quick shifter and broke one of the shifter pivots while trying to force it into gear. Dealer claims no responsibility said it came in that way. I have put 240k mi on that truck and can tell you it was not broken when I brought it in. Not worth the fight, I found one locally for $280 and am going to swap it out. Other than that the truck feels like it has about 150k less miles on it and im very happy to be out of the ford f150 rental.
  11. Jul 27, 2015 at 5:45 PM
    #631
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    This is why I avoid dealers with the truck and car, and why my motorcycles have never been to the dealer.
    I wouldn't even let them fix the warranty things they owed me. I did them myself at my own expense because I don't trust dealers to fix really critical stuff or not screw up something delicate.
    If a dealer screws up something on your bike and you get killed, they'll just tell your wife, "Not our responsibility. It came in that way!"
  12. Aug 17, 2015 at 9:57 AM
    #632
    UglyPornStar
    UglyPornStar New Member
    Jimmy
    Newfoundland Canada
    05 TRD Offroad (Factory Everything)
    Update.
    After waiting nearly 7 months, my truck is finally set to get fixed. Over the course of those 7 months i wasn't contacted once by Toyota, for the record. Various calls to my local dealer where met with the same response every time " Sorry sir YOUR parts are still on back order, and we have absolutely no idea when they will be in." This last friday 1pm, same story. I was at wits end. I called, Toyota Corporate (for the second Time) and proceeded to tell them how ridiculous this was. 7months flapping in the wind, and still no end in sight, no vehicle to drive blah blah blah. She said yeah that sounds horrible, i'll pass this to our service manager here at corporate. Exactly 1 hour later, the d-bag (for lack of a worse term) at my local deal calls me and says " JIM, we worked some magic. All your parts are NOW here! Bring her in on monday."...... In pure disbelief, the only word i could muster was Okay!
    Frigging monkeys.
    Caddmannq likes this.
  13. Aug 17, 2015 at 6:34 PM
    #633
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    If parts weren't available after a month I would be e-mail-bombing Toyota corporate.
    Hell, I should do that over the springs...
  14. Jan 1, 2016 at 12:24 AM
    #634
    grendel
    grendel Well-Known Member
    Tracey
    Saint Cloud, MN
    2005 Blue Tacoma DC TRD Offroad
    stock
    I'm new here. I just bought my 2005 dc trd. Going to crawl under mine tomorrow and take a close look. But Minnesota is not listed on the bulletin. We use salt like nobody's business. If there is an issue I wonder if Toyota corporate would cover it?
  15. Jan 1, 2016 at 2:03 PM
    #635
    grendel
    Tracey
    Saint Cloud, MN
    stock
    Well it was good news for me. Looks like my frame was already replaced. I never thought of going under the truck. I researched these trucks pretty well and knew about somethings to look for.Like the rear leafs, had already been replaced. It was clean. runs great. It looked very new underneath.
    TRDSport10 and DoorDing like this.
  16. Jan 1, 2016 at 2:59 PM
    #636
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Alright..I know I'm being lazy here...I admit it...just found this thread. I have an '06, will be calling tomorrow to make an appointment.
    If they deem mine too dangerous to drive, do they give you a spare? I need a truck that tows my landscaping stuff. If it passes and they undercoat, how long does that take?
    Worst case scenario and it fails...I have an OME set up. Do they put all of that back on? I'm assuming they do.
  17. Jan 1, 2016 at 3:28 PM
    #637
    grendel
    Tracey
    Saint Cloud, MN
    stock
    Actually another member gave me the Web address for Toyota owners. They had all dealership records there. Very nice. Especially for the premium price these trucks go for.
    DoorDing likes this.
  18. Jan 3, 2016 at 7:49 AM
    #638
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    Finally found a fix for the rusting frame and negatively arched rear leaf springs - traded it off 12/7/15 for a 1/2 ton pickup . Piss on Toyota and their games .
    Sarge
  19. May 26, 2016 at 6:11 PM
    #639
    Chuckcosens
    Chuckcosens New Member
    Chuck
    2005 red tacoma
    I am also the second of a 05 Tacoma with rust issues.Toyato did a full frame replacement.They did tell me I would have to pay for any parts that broke in the process.I got lucky and nothing broke during the repairs.However during a rear main replacemnt the shifter shaft and neutral safety switch did break from rust. Those where on my nickel.
  20. Nov 22, 2016 at 7:45 PM
    #640
    Slick-Willie
    Slick-Willie Active Member
    Bill
    AZ
    05 Tacoma
    none
    original owner of a 05 double cab prerunner.... glad i live in dry Arizona!
