2005 tacoma and ethanol
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crazyengineer, Feb 28, 2012.
  1. Feb 28, 2012 at 6:59 AM
    crazyengineer
    crazyengineer [OP] Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    I keep having a few people I know talk about ethanol. They claim that before a certain year (I think its like 2008 or so that he claims) the ECUs in vehicles aren't programmed for ethanol in gas.
    I keep wondering, is it true? If it is, can our ECUs be reprogrammed for the ethanol (since there is so many gas stations that sell it). I know that I can just fill up at non ethanol stations or use an ethanol neutralizer.
    on a side note or 2, if its true, would it help MPG with a reprogrammed ECU (I have searched MPG multiple times)
    I am also going on a road trip soon, so I may do the first have with ethanol gas and 2nd half with non-ethanol and see how much it changes the MPGs
  2. Feb 28, 2012 at 8:18 AM
    crazyengineer
    patrick
    Bristol, TN
    anyone? (if not, i will send it to the top tonight sometime)
  3. Feb 28, 2012 at 10:38 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Ethanol burns faster but it's suppose to be cheaper. Your ECU will adapt and it is safe to run E10 in most 1987+ Toyotas. I think the issue with ethanol was more of it being a strong detergent, it could damage engine parts in some older vehicles.
  4. Feb 28, 2012 at 10:43 AM
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    I see a 3-4 MPG loss when using ethanol gas. Go to puregas.org to find stations that sell regular gas in your area.
  5. Feb 28, 2012 at 10:46 AM
    crazyengineer
    patrick
    Bristol, TN
    already found it and have the app on my phone. I will probably try to fill up like that on my road trip over spring break, i know my usual MPG so i can compare
    also, I have heard that it can gum up an engine somewhat, is that true?
    (i try to run seafoam through my gas tank at least once every 2 months, usually once a month though if that changes anything)
  6. Feb 28, 2012 at 10:48 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Ethanol will eat certain types of seals.
  7. Feb 28, 2012 at 10:50 AM
    krap22
    krap22 Well-Known Member
    I've run the e10 in my vehicles for the last 15 years. No issues at all.
    the 3-4 mpg drop is crap. that is nearly 20% loss in your MPG. That would only happen if you replaced 20% of the gas with something that doesn't burn at all. You may see 1 mpg drop if that.
  8. Feb 28, 2012 at 10:51 AM
    crazyengineer
    patrick
    Bristol, TN
    well, i have a road trip coming up, so thats the best time i know to test it. I will post my results after the trip
  9. Feb 28, 2012 at 10:51 AM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    Im not sure if seafoam really works with our engines.From what a family mechanic told me was that "seafoam is a good product but it was really meant for the engines before in the past.But now we have these engines with new technology and are efficient,there is no need to use seafoam.Just use good quality gas and some good oil with on time tune ups." That guy has been working on our cars for years and I trust everything he recommends.
  10. Feb 28, 2012 at 10:53 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Avoid E85
    Well it's not true. Carbon build happens regardless of engine efficiency. Don't believe me? Clean your throttle body.
  11. Feb 28, 2012 at 10:59 AM
    crazyengineer
    patrick
    Bristol, TN
    I wont go anywhere near E85
    and I probably need to clean my throttle body, I saw a thread on it a while back, i need to find it
    and as for the guy saying we dont need seafoam, it can only help, after what i have seen it do to lawnmower engines, i'll stick with it
  12. Feb 28, 2012 at 11:52 AM
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    E85 is fine if your car/truck has a flex/fuel sensor. The tacomas don't.
    The difference in burning characteristics will basically make your engine not run.
    E85 doesn't burn faster, in fact it has a higher octane rating than premium fuel.
    My MR2 was tuned to run on premium and E85. E85 would allow 25+ PSI of boost, more timing, good for about an extra 100 RWHP on my car. Again it had an aftermarket ECU that I could load dual tunes.
    The drawback is because of the less 'stored' energy in alcohol versus gasoline I needed about 20% more fuel to get the same HP, but obviously for the reasons above I could then gain more because of the higher effective octane rating.
    People say it dries your seals and lines out. I have never seen a case of this so I feel that most modern cars have seals/lines that are resistant enough or the 15% gasoline is enough to offset any drying effect.
    E85 is awesome. Street legal race fuel (~108 octane varies though), your engine runs quieter (really), cleaner and it is usually cheaper (but it's offset by the increased fuel requirements).
