2005+ Tacoma Bolt On Sliders
Discussion in '4x Innovations' started by traxman25, Jul 1, 2011.
  1. Mar 26, 2017 at 9:26 AM
    #181
    ScottyMo
    ScottyMo Well-Known Member
    Scott
    Monterey, CA
    2017 Black TRD OR 4x4
    Making bolt-on sliders for the 2017 DCSB?
  2. Mar 27, 2017 at 11:27 AM
    #182
    traxman25
    traxman25 [OP] 4x Innovations Vendor
    Adam
    Platteville Wi
    Too Many!
    We are not currently offering bolt on sliders, sorry.
  3. Oct 20, 2017 at 8:34 PM
    #183
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    What's your shipping to Canada-land like?
  4. Oct 23, 2017 at 6:41 AM
    #184
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Shipping to Canada is quite expensive, especially for the Long Bed Sliders. However, since this is the bolt on slider thread I'm assuming you are looking for bolt on sliders and we don't have bolt on sliders for the long bed, sorry.
  5. Oct 23, 2017 at 6:48 AM
    #185
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    Damn. I read earlier that you had no intentions on making Double cab long bed slifees, what's the reasoning behind it?
  6. Sep 6, 2021 at 9:27 PM
    #186
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 DCSB OffRoad
    Just got my bolt on sliders and wow they are beefy! Working on painting them and looked ahead to the mounting process but I don’t see any instructions on the website, YouTube channel, or here…
    @traxman25 do you have an install documentation for this product?
  7. Sep 11, 2021 at 12:48 AM
    #187
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    I ordered mine a few weeks ago. Can't wait. Keep us posted on the instructions and how you paint them.
  8. Sep 16, 2021 at 8:02 PM
    #188
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Thank you for you orders guys! We do have an install guide for these bolt on sliders. I know we already got it over to wi_taco, will get it sent over to you too dano.
    wi_taco likes this.
  9. Nov 10, 2021 at 8:15 AM
    #189
    wi_taco
    Adam
    SE Wisconsin
    2015 DCSB OffRoad
    Small preview of finishing using KBS Coatings system (KBS Klean, RustBlast, RustSeal, BlackTop). Might do a final coating of bedliner/undercoating to better match the OEM frame color, not sure yet. Will share more later but too many projects going on right now, crazy dash to get everything done before winter kicks in!
    Thanks for the install instructions Adam. These things are definitely beefy and well made, cheers!
    traxman25[OP] likes this.
  10. Dec 4, 2021 at 5:20 PM
    #190
    wi_taco
    Adam
    SE Wisconsin
    2015 DCSB OffRoad
    Finally had time to process photos and post in my build thread about finishing with KBS Coatings.
    TLDR is that I would never hang them from the rafters like I did, and 100% doing aerosol/spray gun only for future projects. Brush-on method sucks balls. KBS Blacktop in FLAT finish is the hot ticket for people living in the rust belt (otherwise I'd do Rustoleum rattle cans).
    Still working to get them installed - no time thanks to work/life, also having an issue mounting the front square nuts that I already called Adam about. Will share photos later if I get them installed before snow flies.
    Also if anyone is curious I weighed them after paint and it comes to about 65 lbs each slider not including hardware. Original tube steps are 30 lbs each. Net gain is ~70-80 lbs total. These are BEEFY.
    danojeno likes this.
  11. Jan 15, 2022 at 10:01 PM
    #191
    wi_taco
    Adam
    SE Wisconsin
    2015 DCSB OffRoad
    Finished installing the sliders back on New Years and just now going through photos. Figured I'd share here for those looking to see how they look on a 2nd gen. I wanted to be sure and share the photo showing how far the sliders "poke" out from the body/frame as I haven't seen a good photo showing that yet. These sit nearly flush with my SCS BR6 -10 offset wheels and 265/70/17 tires.
    One oddity was I could only install 2 of the larger bolts going through the frame horizontally, not sure if 2nd gen can do all 3 like the instructions say for a 3rd gen. Mine does have a hole/location for that bolt, however the frame has some overlapping metal at that point so I felt the square nut would sit off-kilter and I didn't immediatly feel warm and fuzzy about it. I'll give it another look come spring when temperatures are higher since I don't have a heated garage. Good news is they aren't going anywhere with 2 bolts + the 1 bolt in front crossmember + brackets.
  12. Jan 18, 2022 at 7:46 AM
    #192
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Looks good! For the bolt you had the question about, it is fine to bolt it down. It won't cause any issues in this application and is better to have the clamping force it does provide than nothing at all.
    wi_taco likes this.
  13. Mar 27, 2022 at 3:38 PM
    #193
    Spankomatik
    Spankomatik Well-Known Member
    JD
    IL
    2023 celestial silver metallic SR5 4x4 2.4L
    @traxman25 ,
    I want to buy bolt on sliders for my AC. The part number on the site is 1311300. Would these fit an ACLB 4cyl 4x4?
    Also, I'm not too far from you guys. Do you offer a pickup option? It would be a great excuse for a quick road trip.
    Thanks in advance!
  14. Mar 27, 2022 at 3:39 PM
    #194
    Sean42
    Sean42 Well-Known Member
    Do you make them for 05-15 regular cab?
  15. Apr 5, 2022 at 7:10 AM
    #195
    traxman25
    Adam
    Platteville Wi
    Too Many!
    I'm not sure if the 4cyl has the trans cross member in the same place. Since you're close if you'd like to setup a time to come by the shop we could test fit a set to see. As far as I know that would be the only difference.
    We do have weld on sliders, but not the bolt on sliders for the regular cab, sorry.
