2005+ Tacoma Bolt On Sliders
Discussion in '4x Innovations' started by traxman25, Jul 1, 2011.
  1. Jul 19, 2011 at 7:55 PM
    #41
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    Adam, I will order my set tomorrow.
  2. Jul 19, 2011 at 7:58 PM
    #42
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    if these will fit on an access cab I will deff get a set ordered asap
  3. Jul 20, 2011 at 6:50 AM
    #43
    oZmonKey
    oZmonKey Big Metal Hubajube
    Northern Colorado
    Black 98
    Unknown Spacer Lift.
    Thanks for clarifying.
    I'd offer my truck for test fit, but it's a 15 hour trip, one way.
    Hope you can find someone closer.
  4. Jul 22, 2011 at 4:47 AM
    #44
    traxman25
    traxman25 [OP] 4x Innovations Vendor
    Adam
    Platteville Wi
    Too Many!
    Today is the last day to get a great discount on these beefy sliders! Get your order in and don't miss out saving $60!
  5. Jul 22, 2011 at 3:44 PM
    #45
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Got mine ordered!
  6. Jul 23, 2011 at 12:46 PM
    #46
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    Can't wait for mine to ship.
  7. Aug 7, 2011 at 5:53 PM
    #47
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    My Sliders En Route.:D Come on Wednesday!
  8. Aug 7, 2011 at 6:10 PM
    #48
    hellrazor004
    Rob
    09 DCSB
    I got a tracking number Saturday, but no carrier. Do you know what company they were shipped with?
  9. Aug 7, 2011 at 6:23 PM
    #49
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Should be fedex. Just copy the number and google search it. The search will come back with a carrier.
  10. Aug 8, 2011 at 1:21 PM
    #50
    hellrazor004
    Rob
    09 DCSB
    Woot - should be here Wednesday!
  11. Aug 10, 2011 at 9:31 AM
    #51
    hellrazor004
    Rob
    09 DCSB
    Haha - Quoted from the girlfriend...
    "sliders are here. and so big and heavy i had to help the fed ex lady get them out of the truck"
  12. Aug 10, 2011 at 10:46 AM
    #52
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Mine are here as well. Prepping and painting them now.
    Getting the pops off, marine clean, metal ready, por15 then top coats.
  13. Aug 10, 2011 at 11:46 AM
    #53
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    where did you buy your POR15 from? i got a paint sprayer speciffically to use with that stuff, but haven't ordered the POR15 yet. my whole undercarrage is getting coverered with it.
  14. Aug 10, 2011 at 11:53 AM
    #54
    traxman25
    Adam
    Platteville Wi
    Too Many!
    http://www.por15.com/
    I looked into becoming a dealer but I don't think I could sell their buy in in a year. :( Great paint though.
  15. Aug 10, 2011 at 12:42 PM
    #55
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    wow, they must require a pretty big order. that's unfortunate. i'd buy it from ya :)
  16. Aug 10, 2011 at 1:20 PM
    #56
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Yes. Most places do.
  17. Aug 10, 2011 at 5:48 PM
    #57
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Most automotive paint places have POR as well. I have two places right near me that carry it.
  18. Aug 11, 2011 at 6:32 PM
    #58
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Two more bolts and all done.
    Here is how I installed it
    -take out the bottom cross member bolt
    -get the slider into place and put a tapered head bolt into the hole of the cross member bolt.
    -put a side bolt in near the most rear side bolt hole that needs to be drilled and snug it up
    -mark the rear side plate hole with a center punch
    -unbolt everything and take the slider down to drill the rear hole
    -put the slider back into place the same way as earlier
    -put all the side bolts in tight to snug the plates to the frame.
    -mark the bottom tapered bolt holes with a center punch
    -drill all the holes
    -I painted the holes I just drilled with por15 so they don't rust
    -loosen all the side bolts and bolt the bottom bolts nice and tight
    -go ahead and tighten all the side bolts
    The only bolt (on each slider) I wasn't able to do was the tapered bottom bolt in the front. It's in the boxed out section of the frame and there is no way to get your arm back there and get a nut on that tapered head bolt. I suspect that holes need to be drilled and tapped. there really needs to be a bolt in this position. Hopefully Adam will chime in and let us know what the scoop is for that.
    These bolt on sliders are beefy and am excited to get them on the trail next weekend. The plates matted perfectly to all the holes and bolts on the frame. No modification required at all!
    Enjoy
  19. Aug 17, 2011 at 1:28 AM
    #59
    1expensiveTaco
    1expensiveTaco Active Member
    Steven
    Washington
    07 Tacoma Access Cab 4x4 V6
    Any update on whether these mounts will fit the frame on an AC LB? I want these so bad
  20. Aug 18, 2011 at 10:13 AM
    #60
    traxman25
    Adam
    Platteville Wi
    Too Many!
    I haven't actually fit up a set to know for sure.
