2005+ Tacoma ICON RXT Rear Suspension
Discussion in 'SDHQ Offroad' started by SDHQ OFFROAD, Jul 13, 2017.
  1. Apr 28, 2019 at 7:12 PM
    #121
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Ran into a snag. Broke a u-bolt. So cut the other off and will have new ones made Monday. Trying to decide if I should take one of the overloads from the old spring back and use it as a spacer. Old pack is the old Dakar pack with the Dakar add a leaf the factory Tacoma overload which is 1/2" and a cut down tundra overload that is 3/4". The shocks I had custom built for this setup so I have to be careful of pack thickness. I have 3" of shock shaft left when I touch my Timbren. So with Timbren squish I feel like I have 1.5" of pack thickness to play with.
    Hookedup likes this.
  2. May 4, 2019 at 9:38 PM
    #122
    pdhdz22
    pdhdz22 New Member
    3rdgen silver DCLB
    I have the icon stage two and was wondering if I got the rxt leafs would I be ok with those shocks? Also does anyone add the icon mini pack to the rxt leafs? Or is unnecessary?
  3. May 5, 2019 at 5:17 PM
    #123
    ChiefBrody
    ChiefBrody Well-Known Member
    Michigan
    '12 Tacoma TRD Offroad
    Just got mine finished up today. Went with option 3 paired up with the Pro Bilstein kit.
    Before/after gained ~6” in the back. More that I was expecting, but I think my stock suspension was shot.
  4. May 6, 2019 at 3:34 PM
    #124
    Hookedup
    Hookedup Well-Known Member
    SOFLO
    2012 DCSB SPORT/ 2019 OR DCSB
    FOX 2.5 DSC/ICON RXT/SPC UCA
    Ummm 6” is a bit excessive..
    Edit: i guess if your stock springs had sagged out.. it might be right
    Ruru likes this.
  5. May 6, 2019 at 3:53 PM
    #125
    SDHQ OFFROAD
    SDHQ OFFROAD [OP] Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    Normal lift is 2.625" of lift on option 3 with no weight in the bed.... 6" seems pretty excessive. Did you drive it around at all to see where it settled?
  6. May 6, 2019 at 3:56 PM
    #126
    ChiefBrody
    Michigan
    Just got back from an alignment and driving around for a bit.
    I’ll go out and measure it again tonight.
  7. May 6, 2019 at 5:14 PM
    #127
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    I did end up getting my springs all on and I ended up 1" lower than what I started with. But that was with all the extra spacers(overloads) bolted into the pack. So all said and done, I am at 25.5" from center of hub to fender, with no flares. Expecting at least 1/2" of settling. So to keep the stance I want I am going to lower the front an inch also. Which is probably needed since I measure 24" up front from center of hub to fender with no flares. I do also have 5/8" more exposed thread on the drivers side than the passenger side for the taco lean. Going to maybe relieve a little of that difference also. But the RXT's ride so much more smoother than the old OME's. And I can now droop to the full 29.5" of shock that I have. Going to flex it out and stuff the rear tonight to see how close I come to bottoming the shock out.
  8. May 9, 2019 at 3:38 PM
    #128
    Hookedup
    SOFLO
    For what it’s worth i just went from option 1 to option 2 (i swapped the extra leaf) the ride is noticeably stiffer in the rear unloaded. I’m not sure if the new leaf needs to break in some but it feels pretty stiff. Most of the time I ride pretty empty but i do carry heavy loads from time to time. I loaded the bed on option 1 and had some significant sagging. Not sure if I’m going to keep it on option 2 since I’m empty from my day to day or go back to option 1.
  9. Sep 4, 2019 at 9:46 AM
    #129
    SlowPoke Rodriguez
    SlowPoke Rodriguez New Member
    2015 TRD Sport DCLB 4wd
    How has this setup worked out for you? I just ordered the TRD pro kit and this leaf pack.
  10. Sep 4, 2019 at 9:55 AM
    #130
    ChiefBrody
    Michigan
    Working great. I can’t speak to the stiffness of the rear leaf pack because I have nothing to compare it to, but I have no problems with it. I wouldn’t consider option 2 at this point as 3 is just fine. I do have a topper and rack on it, but driving around with an empty bed feels fine.
    I went option 3 because of the topper and rack, but also because I occasionally tow a small camper (100’ish tongue weight) and the bed loaded up with lord knows how much weight.
    I’ve had a couple hundred pounds of shit back there and it doesn’t even flinch.
  11. Sep 4, 2019 at 10:49 AM
    #131
    SlowPoke Rodriguez
    Thanks for the report! I think I’ll do the same. I run an ARE MX with rack on top plus a platform and gear inside and usually mountain bikes hanging off the back. I’m really looking forward to getting off the bump stops!
  12. Dec 8, 2019 at 10:12 AM
    #132
    Georgia Native
    Georgia Native Well-Known Member
    4x4 DCLB 2017 SR5, 2019 4runner Offroad, 2021 SR Access Cab
    I am planning to do the same setup on my truck. Any problems or complaints? Sill happy with the rxt leafpack? I appreciate it.
  13. Dec 13, 2019 at 4:14 PM
    #133
    Raccoon6
    Raccoon6 Member
    13 Tacoma
    I ended up with about 4 inches of lift in the rear on Option 3. I have a decent amount of shudder between 5-15 MPH. Tried 1/2 inch carrier bearing spacers, and shims... neither really helped. I am going to switch to 3/8 in spacers to see if i can reduce the shudder.
    In hind sight, I should have went with Option 1. I still cant get over the amount of lift I got with Option 3 - definitely more than 2.65 inches.
    It is definitely stiffer than stock, but a good ride nonetheless. Love the look, but dislike the shutter. IMG_6834.jpg
  14. Dec 13, 2019 at 4:21 PM
    #134
    Raccoon6
    Raccoon6 Member
    13 Tacoma
    You will also need to get creative with emergency brake lines. They may catch or rub on the spring clamps. I zip tied some hose protector and in the rub areas - seems like a good fix for now. You may need to either flip or trim the spring clamp bolt nearest the fuel cell, as you could have some clearance issues. I was okay with my set-up.
  15. Dec 16, 2019 at 12:03 PM
    #135
    Raccoon6
    Raccoon6 Member
    13 Tacoma
    I got over 4 inches on option 3. By the time I added a shim to help with the shudder, I am closer to 4.75 inches.
  16. Mar 23, 2020 at 10:33 AM
    #136
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Does anyone know the compressed and extended lengths of the Icon RTX Omega Bypass shocks?
    Pin face to lower eye.
    @SDHQ OFFROAD
  17. Mar 23, 2020 at 3:34 PM
    #137
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Extended: 25.1
    Collapsed: 14.75
  18. Mar 23, 2020 at 3:35 PM
    #138
    Sterling_vH111
    Sterling
    socal
    Thank you !
  19. May 29, 2020 at 9:34 PM
    #139
    91Bravo
    91Bravo Well-Known Member
    Van
    Bay Area
    16Tacoma4x4TRD
    Icon RXT 2.5 RR CDCV paired with Deaver Stage III vs Allpro Expedition leaf spring with Icon 2.0
  20. Apr 22, 2021 at 12:07 AM
    #140
    culveremt
    culveremt Member
    2020 TRD OR DCLB
    @SDHQ OFFROAD i purchased my RXT setup from you guys recently and was hoping to keep my lift around 2-3inch to avoid vibration issues. Like another person here, I got 5 inches in lift in the rear in option two (with approx 400-500lbs constant in the rear). It settled about 3/4 of an inch, and I’ve pulled everything apart, repacked the springs to make sure I didn’t put the aal in backwards, and retorqued everything. It’s still way more of a raise than I wanted which has led to my newest enemy: vibrations.
    I absolutely love the suspension over stock and have been looking into adjusting the drive train geometry to keep it. However, in reading, it seems like it’s a cv bushing issue.
    Vibrations are very subtle around 20-45mph (mostly in the 40 range), but felt/percieved mostly everywhere. Wheel, pedals. floorboards. I almost would say I was imagining it and that my truck always drove like that, but it goes away immediately in 4Hi.
    Anyways, you guys are my go to shop. Have you installed many ECGS bushings and do you find they help more than just shims?
