2005 tacoma replace u-joints and yoke is extremely stiff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bluetacoma40, Aug 10, 2023.
  1. Aug 10, 2023 at 3:40 PM
    Bluetacoma40
    Bluetacoma40 [OP] New Member
    2005 tacoma prerunner sr5 trd
    2005 tacoma prerunne replace u-joints and yoke is extremely stiff now. If I reinstall driveshalf will it start to break in a little or stay stiff and or slowly ruin transmission? The spot were the retainer clips go go a tiny bit pushed in but retainer clips still go in with new u- joints. I took it back apart again because it was so stiff and has little give when I move it around and want to try and get it right before I put driveshaft on truck. Just replaced center bearing for 3rd time now and went ahead and replaced the extension seal on tranny because it was leaking also. Sick of dealing with this don't know how many time I can keep taking these u-joints on and off trying to get it to go on with and not be so stiff once retainer clips in about to give up. Any advice much appreciated thank you
  2. Aug 10, 2023 at 3:50 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Whenever I do ujoints I always tap the caps with a ball peen hammer to make sure they are not bound up. 99% of the time this works. If they are still tight then I have messed up.
    Sometimes new ujoints can flop around, and other times they are firm, but not tight. Might need to pull it and tap the caps and feel it in your hand.
  3. Aug 10, 2023 at 4:31 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Are they new u joints you are putting in?
    I know they do come with different thickness retainer clips.
    TnShooter likes this.
  4. Aug 10, 2023 at 4:37 PM
    Bluetacoma40
    Thanks for responding. I just called 3 o'riellys auto parts and one guy supposedly just confirmed that the u joint that goes to the yoke and transmission end is millimeters in deference from the other 2 u joints and he guarantees this is the issue. Going to pick up now and see if this is why it's so stiff and no play. I was looking at my old retainer clips thinking of using trying those as well. Has anyone heard of this since I am buying 2 ujoints and a 3rd that's different?
  5. Aug 10, 2023 at 5:01 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  6. Aug 10, 2023 at 5:07 PM
    nd4spdbh
    SoCal
    All rear u joints are the same size.
    You want 3 of these to do your rear driveshaft
    https://www.amazon.com/gp/product/B00DOI8BDS?ie=UTF8&th=1
