2005 tacoma supercharger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dylanmclean, Dec 3, 2019.
  1. Dec 3, 2019 at 7:37 PM
    Dylanmclean
    Dylanmclean [OP] Active Member
    Dylan
    Red 2005 tacoma
    I have a 05 tacoma 4.0 without the hood with hood scoop. Ive heard that you need the hood scoop in order to clear the supercharger that Toyota used to offer from the factory. is this true or can I run the hood I have??
  2. Dec 3, 2019 at 7:41 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You dont need a different hood
    SR-71A likes this.
  3. Dec 3, 2019 at 7:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    no need. the hood scoop offers no extra clearance inside the engine bay.
  4. Dec 4, 2019 at 4:24 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    What will a supercharger do to that weak head gasket? :crapstorm:
    TegoTaco likes this.
  5. Dec 4, 2019 at 4:47 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Yeah but supercharging is the most fun way to find out :D
  6. Dec 4, 2019 at 4:49 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    190k on my '05. 75k of that has been with boost and a smaller pulley. Very much a story of YMMV
    BassAckwards and DG92071 like this.
  7. Dec 4, 2019 at 9:34 AM
    Dylanmclean
    Dylan
    Red 2005 tacoma
    Planning on possibly changing the heads to the newer ones and at the same time changing the head gasket to somthing better.
  8. Dec 4, 2019 at 10:04 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    The best head gasket is the updated Toyota head gasket.
    As for the charger, you probably know that when you add boost to any application, you'll be stressing the head gaskets anyway. Knowing that, you can rule out "if" and set some time and money aside for "when" and just have fun with it. Whether you do that now or later is up to you. Swapping a head gasket (or two) is a ton of work, but if you can turn a wrench, it isn't the end of the world some make it out to be. If you do it later, just monitor engine temps, fluid levels and shut it down ASAP if anything is amiss.
  9. Dec 4, 2019 at 10:48 AM
    DG92071
    DG92071 Well-Known Member
    I wasn't aware the heads themselves changed, I thought only the head gasket changed.
  10. Dec 4, 2019 at 6:22 PM
    Dylanmclean
    Dylan
    Red 2005 tacoma
    If I have my information correct, in 2009 they put vvti on the exhaust and intake side of the camshafts as opposed to just the intake. which should make more power and possably better fuel efficiency.
  11. Dec 4, 2019 at 6:30 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Muddinfun and BassAckwards like this.
  12. Dec 4, 2019 at 6:56 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    No you don’t need a hood scoop....but it does add 25hp to all trucks that have it.
  13. Dec 4, 2019 at 7:45 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You dont need a hood,use what you have,it will clear a supercharger.
  14. Dec 4, 2019 at 9:27 PM
    DG92071
