2005 toyota tacoma head gasket problem
Discussion in 'Technical Chat' started by maykups, Nov 16, 2017.
  1. May 31, 2018 at 8:06 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    I understand your complaint, I had the same complaint when a mechanic at my dealer told me that Toyota knows about the problem with the 2005 and 2006's. But what he recommended was save my receipt from getting it fixed and "IF" they ever do a recall they will reimburse for the work I had done. But the "IF" is doubtful. And I wasn't going to let my truck sit waiting. So I had it fixed and I am glad I did.
  2. Jun 1, 2018 at 6:31 AM
    tacomoreno
    tacomoreno Member
    Arturo
    Indianapolis
    2006 Toyota Tacoma sr5 sport
    Head unit and rear camera haha
    So bishop84 you trying to say all Tacoma’s need around 120k miles a head gasket change as routine maintenance? Should be a dealer recall if it’s a design problem
  3. Jun 1, 2018 at 6:35 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    How did you catch yours early?
  4. Jun 1, 2018 at 3:51 PM
    tacomoreno
    tacomoreno Member
    Arturo
    Indianapolis
    160k miles is early?
  5. Jun 1, 2018 at 8:32 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    I was lucky enough to pull over to stretch my legs coming home from an over night fishing trip. The truck wasn't over heating but when I shut the truck off it over flowed coolant from the over flow bottle and left white crusty material when it dried. I went to the mechanic that did the work and he said that sounds like a head gasket, But I went to the dealer to see what they said and they really weren't sure. So I went back to the mechanic that did the work and we looked in the radiator for bubbles and he was right. So it went in two days later. So dry white crusty material around the radiator cap, Over flow bottle cap are good signs But the sure sign is the bubbles in the radiator when the truck is running.
  6. Jun 1, 2018 at 8:33 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    Mine went somewhere around 137,000 if I remember correctly.
  7. Jun 2, 2018 at 5:29 PM
    tacomoreno
    tacomoreno Member
    Arturo
    Indianapolis
    What’s my complaint it’s my first Toyota and I’m disappointed, I thought Toyota last longer before this big investment
  8. Jun 2, 2018 at 10:23 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    We picked the Lucky years for the problem. But think of it this way, If you decide to get it fixed, Hopefully it will turn out good like mine and you will have a good one and that will be you're only issue and it will run forever will the normal maintenance.
  9. Jun 3, 2018 at 8:34 AM
    tacomoreno
    tacomoreno Member
    Arturo
    Indianapolis
    I heard the after the head gasket issues is the transmission, it’s that true? Again we are talking trucks with 130/169 miles!!!!
  10. Jun 3, 2018 at 9:07 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I've read in the past that the problem was caused by temperature differences between the cast iron block and the aluminum head causing the gasket to tear. They allegedly replaced the material sometime in 2006. I'm hoping mine made the cut.
  11. Jun 3, 2018 at 9:19 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    The guy at her work is probably minorly versed in vehicle problems. A common head gasket failure is when coolant gets into your oil. But head gaskets fail in different ways depending on the flaw in the design. This one appears to leak compression into the cooling system like the diesels I work on.
    And I understand your frustration OP, but Toyota put a warranty on that vehicle for a certain time and mileage. You've exceeded those parameters by a good margin. I'm sorry for your unfortunate circumstance, but Toyota isn't liable for this anymore and shouldn't be expected to foot the bill. It's your truck. If your lawn mower has a 3 year warranty and the engine goes after 5 years, would you call that company and expect them to fix it? If your household appliance (dishwasher, drier, washing machine, or refrigerator) has a 2 year warranty and stops working after 2 and a half years, all those companies will tell you you the same thing. Not their problem. It made it out of warranty. It will be X dollars to fix it.
    At this point you need to evaluate your options. Do what a lot of people are suggesting and replace the engine with a low mileage used one (but expect the head gaskets to go around 150k) or perform the repair that Toyota is recommending. I'd ask if there are updates parts that prevent the head gaskets from blowing again (like a differently designed head gasket) or if ARP studs might help (they do in diesel world).
    I'm a bigger fan of dealerships than independents. It's a familiarity thing. A tech at a dealer sees the same engines over and over and (if hes like me) has all the bolt sizes and locations, how the wiring runs, and everything else committed to memory. An independent shop works on all makes and models and is much less likely to have that information memorized. I'm not saying an independent shop will do bad work, but I'm saying I trust a dealer a little more. And if you're not happy with the work, there's more you can do at the dealer (talk to management and corperate) if you dont like the service you got. An independent can tell you to go pound sand and if BAR sides with them, you're SOL.
    Bottom line: engine or head gaskets? Dealer or independent? Up to you, it's your money and your truck.
  12. Jun 3, 2018 at 12:18 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    I am just shy of 200,000 miles on my 2005 without and transmission issues. I started changing fluids early by doing a Pan Drop NOT!!!! A FLUSH!!!!! I have had past issues when I have had a flush done with two other trucks and will never have another one done. Yes they had a lot of miles but will never have another flush done either way.
  13. Jun 3, 2018 at 12:20 PM
    FirstTimeFirstGen
    David
    Pacifica
    I'm not a fan of "flushes." Drop pan. Change filter and gasket. Reinstall pan. Fill with fluid.
    But I'm missing what this has to do with the OP.
    :stayontopic:
    MARSHBUSTER[QUOTED] likes this.
  14. Jun 3, 2018 at 7:26 PM
    tacomoreno
    tacomoreno Member
    Arturo
    Indianapolis
    I’m thinking to swap for a low mileage engine, what do y’all think?
  15. Jun 3, 2018 at 7:28 PM
    #35
    MARSHBUSTER
    Jim
    Alamogordo NM
    Go back to post #29 LOL.
  16. Jun 3, 2018 at 7:35 PM
    #36
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I'd sell it and do not mention the head gasket problem !!!
    tacomoreno likes this.
  17. Jun 3, 2018 at 7:39 PM
    #37
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    That’s messed up dude
  18. Jun 3, 2018 at 7:43 PM
    #38
    MARSHBUSTER
    Jim
    Alamogordo NM
    I thought about doing that with mine, But I didn't want to start the payment process all over again. The other side of that is. When they did mine, I had them replace my water pump and of course it had all new gaskets when it was put back together so if anything was getting ready to start leaking that was caught. Plus I was able to see my motor in pieces and everything looked great with 137,000 miles on it.
  19. Jun 3, 2018 at 8:10 PM
    #39
    tacomoreno
    tacomoreno Member
    Arturo
    Indianapolis
    It if I get one with 90k miles newer model? I heard this problem affected 05, 06 models only
  20. Jun 3, 2018 at 8:11 PM
    #40
    MARSHBUSTER
    Jim
    Alamogordo NM
    That is correct.
