2005+ Upper Dash Removal HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05Taco4x4, Jul 23, 2011.
  1. Jul 23, 2011 at 3:25 PM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    4x4 Conversion, FJ case, Manual Hubs, 2017 Suspension, TSB Leafsprings, 2015 Interior update, 2017 Head unit, Lock on start, Mirror Riser
    How do I remove the "upper part" of the dash [by "upper part" I mean the part the sun hits] ? Searched this forum and the internet without any luck. I can't find it on http://www.ncttora.com/fsm/index.html either.
    thanks[​IMG]
  2. Jul 23, 2011 at 8:59 PM
    Silver DC
    Silver DC Well-Known Member
    Mark
    Nashville
    07 TRD Prerunner SuperCharged
    Supercharged,TRD CAI, TRD exhaust, DTLT Headers, L.E.D. Taillights, Factory BHLM,Wet Okole Seat Covers,Weather Tech Digi-cut Floorliners
    The upper dash is the whole dash. Everything has to come out to take it out.
  3. Jul 23, 2011 at 9:14 PM
    05Taco4x4
    2TR-FE Enthusiast
    i understand that... so once the radio, ac controle, glove box, lower panels, speedo cowl, speedo and such are out, how exactly do i go about getting this out?
  4. Jul 23, 2011 at 9:26 PM
    Silver DC
    Mark
    Nashville
    The dash has some 10mm bolts that hold it in. I cant remember it all but they were all easy to find. There are some clips that hold it to the fire wall, but you should just be able to pull on it to get those to come loose. i also had to remove the airbag from the passenger side before I could get it out. I suggest you disconnecting the battery way before you fool with the airbag. I just kept on tugging on it and where ever it wouldnt pull loose, I knew that I had missed something and would look for another bolt that was holding it. kept doing this until I finally got it out. I had no instructions just the need to take it out.
  5. Jul 23, 2011 at 9:34 PM
    Silver DC
    Mark
    Nashville
    Oh and you also will have to remove the console. There are bolts under the carpet piece inside of the console. The carpet piece is glued to a hard plastic part. You will have to pull or pry it up to get it out of the glove box.
  6. Jul 23, 2011 at 10:53 PM
    05Taco4x4
    2TR-FE Enthusiast
    ok, thanks
    i've already got the console out so that makes things easier
    do you recall about how many bolts, 4~5 or like 10~15
    thanks, i knew someone here had to do this at one point or another
  7. Jul 24, 2011 at 9:06 AM
    Silver DC
    Mark
    Nashville
    More like 10 to 15. IIRC.
  8. Oct 13, 2011 at 9:40 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
  9. Oct 13, 2011 at 12:48 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    i cant remember if i had to drop the steering assembly at all , but maybe some pics would help . like others have said , systematicaly go through the whole dash removing all the 10mm head bolts , every piecs on or around has to be taken off, remove the bolts that hold the passenger airbag to the inner frame. then yiu have to pop the clips out of the firewall by just pulling back on the dash from one end , then the other and it pops right out
  10. Oct 13, 2011 at 2:43 PM
    05Taco4x4
    2TR-FE Enthusiast
    i appreciate it
  11. Dec 1, 2011 at 7:29 PM
    05Taco4x4
    2TR-FE Enthusiast
    stole photo :rolleyes:
