2006 2.7L owner w/ problems
Discussion in 'New Members' started by SwollenTaco23, Feb 14, 2010.
  1. Feb 14, 2010 at 8:07 PM
    SwollenTaco23
    SwollenTaco23 [OP] Member
    Wendell
    Boise, ID
    Hello All,
    Joined Tacoma World not too long ago and have been lurking around here enjoying all the mods and things guys put up on here. I finally decided to introduce myself and my 2006 2.7L Reg Cab. 4x4. I love the truck. I bought it new with 0.0 on the odometer. I have only done secondary air filter removal so far. As soon as the tax return comes in I'm putting a spacer kit on it with pro comp black crawlers and 33" BFG A/T's.
    I just changed the oil in it today after the maint reqd light came on. I tried holding down the trip button as I have read that that "resets the computer" or whatever? :confused: That didn't work... The stupid TPMS light has been blinking for months and the dealer wants 40 bucks to turn it off.:eek: All of the tires are at precisely the same pressure and still will not reset with the button under the steering column. The other thing that has been irritating me is the rattly catalytic converter. I think it is the one closest to the muffler. Do any of you suggest taking the pipe off and beating out the inside of the cat? It is really obnoxious on the freeway and I would like to "fix" it before I throw down the money for the complete exhaust upgrade. Any replies are appreciated.
  2. Feb 14, 2010 at 8:08 PM
    matt86
    matt86 Well-Known Member
    NC
    2008 Tacoma SR5 4x4
    Welcome to the forum! When you checked your tire pressure did you check the spare also?
  3. Feb 14, 2010 at 8:18 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    hold the trip reset button then put key in and turn to the on or whatever position without turning it on. hold till all the buttons are gone for 5k intervals for maintenance light
  4. Feb 14, 2010 at 11:37 PM
    SwollenTaco23
    Wendell
    Boise, ID
    thanks. that worked for the maintenance light
  5. Feb 15, 2010 at 2:17 AM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    I used a piece of black tape to cover my TPMS light. One of my sensors went and I've got better places to spend $125!! Just take the instrument panel out and cover it up if you don't want to see it, that is after you've ensured that ALL the tires are aired up identically.
  6. Feb 15, 2010 at 3:57 AM
    silvertaco82
    silvertaco82 No way, get real
    Bozeman, MT
    2010 AC TRD Sport 4x4
    TRD Seat Covers, Weathertech floor mats, Sockmonkey Decals, Pro Comp 6", 35" Nitto Trail Grapplers, 18x9 XD addicts, 20% tint, Kenwood Dnx 5120, 2 10" Kicker Shallow mount subs
    +1 go with billies spacers suck!
  7. Feb 15, 2010 at 4:41 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Welcome Aboard!
  8. Feb 16, 2010 at 1:23 PM
    SwollenTaco23
    Wendell
    Boise, ID
    I checked all tires including spare. One of the sensors must be bad. I think I'll just pull the led and keep the sensors out of the new wheels. Thanks. I'm just doing the spacer lift for now so I can admire what the bigger tires look like. Down the road I'm doing the all pro long travel kit so I'm not going to make a bigger investment than the spacer at this point. Thanks for all the advice.
  9. Feb 16, 2010 at 1:31 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    The sensor that is in the tire can be reset at most tires shops. It is simple and straight forward.
