2006 4x4 double cab helper leaf installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bradleyswine, Nov 19, 2011.
  1. Nov 19, 2011 at 2:56 PM
    bradleyswine
    bradleyswine [OP] Member
    Texas
    Tacoma 4x4
    I installed the single leaf helper and completed the install today. The leaf installs much easier "IF" the installer does not trim the centering bolt for the leaf springs prior to installing and tightening the bolt.
    After the install the the rear of my truck is definitely higher. The truck also rides different in the short amount of time that I spent on the road. Total cost not counting the pair of extra centering bolts that I had to purchase due to cutting the original bolts.
    Products
    1 x 1995-2011 Toyota Tacoma 4wd - Add a Leafs (REAR - 2" Lift) (85250) =
    $42.95
    Sub-Total: $42.95
    United Parcel Service (Ground): $14.93
    Total: $57.88
