2006 Subie STI rebuild
Discussion in 'Other Builds' started by xtremewlr, Aug 6, 2021.
  1. Mar 30, 2022 at 9:57 AM
    #241
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I was updated on the turbo situation yesterday, we are now switching to the Blouch Dominator 3.5XT-R turbo. SteamSpeed has never responded nor updated the tuner/garage after multiple inquiries and calls from them. So fuck SteamSpeed. They may make a great turbo but the customer service is non-existent.
    Another change is that we are now switching to a NA long runner intake manifold from Outfront. This will eliminate the need for TGV deletes all together, as well as giving a slight bump in the power numbers. I've read as much as 25hp but we'll see where this build ends up at. Still shooting for 400+ wheel hp on 91 octane pump gas. It's going to make mounting the TMOC more of a challenge tho. Good thing I have a massive hood scoop now, we might need to cant the cooler up at the back, thru the hood opening. Not a bad thing tho as that will put it more directly in the air stream.
  2. Apr 4, 2022 at 6:43 PM
    #242
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Hood has been repainted. Last remaining silver is the roof and that's wrapped black for the time being. I'm over sanding and painting for a while.
    This is far from a professional job. The paint did not come out perfect. It's from a spray can and it's metallic, so not very easy on such a large surface. I think maybe the trunk came out a little more consistent. I don't really care either way. The silver is gone and I am much happier with even a shitty paint job now that the color is all pretty much the same. Honestly, I think my shit spray can paint job might be better than the silver paint job was.
    Sanded and primed before this. This was the first coat of the blue. I ended up using 2 and a half can's of the GrimmSpeed WRB paint. Followed up with 3 and 3/4 cans of clear.
    Wet sand and then compound and polish next weekend. Then I'll reinstall it on the hood and get the hood scoop mounted again.
  3. Apr 7, 2022 at 10:22 PM
    #243
    Kofe513
    Kofe513 Member
    Kolby
    2018 Inferno TRD OR DCLB
    Damn man, just got caught up on this build. Things went 0 - 100 real fast! Looks like it's going to be a hell of a lot of fun when it's done!
    xtremewlr[OP] likes this.
  4. Apr 8, 2022 at 7:09 AM
    #244
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, they sure as hell did!
    Getting really close now. Just waiting on the heads to come back from the machine shop now. They built the new OEM heads the first time around with the good parts specified by the tuner but didn't do the pocket porting they were supposed to. So the heads went back for that. We talked to the machine shop yesterday and they were about 90% done with porting one head and the machinist was telling us that he wasn't happy with the factory valve angles so we are going to have those redone since they are there. So hopefully we have the heads back next week sometime. That's all we are waiting on now to build the motor. Turbo is still on order but because I don't need that for a little while still, it's not holding anything up.
  5. Apr 8, 2022 at 7:12 AM
    #245
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Oh, also picked this up yesterday while I was at the tuner's garage. NA long runner intake manifold. Working on painting it wrinkle black.
  6. Apr 8, 2022 at 2:35 PM
    #246
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    NA intake is now wrinkle black. Looks pretty good I think.
    Finished the hood. Could really use someone to polish it that actually knows what they are doing but I'm happy enough with it for now. No more silver!
    The hood scoop is huge, I dig it.
  7. Apr 8, 2022 at 2:50 PM
    #247
    Phessor
    Phessor Well-Known Member
    What is the advantage to the NA intake?
  8. Apr 8, 2022 at 2:52 PM
    #248
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Long runner on the NA vs short runner for the original intake. Should give better power over the entire rpm range.
    Phessor[QUOTED] likes this.
  9. Apr 8, 2022 at 2:54 PM
    #249
    Phessor
    I'll bet it is going to be blast to drive when you're done.
    xtremewlr[QUOTED][OP] likes this.
  10. Apr 8, 2022 at 2:54 PM
    #250
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    The day I bought it.
    And this is now.
    Kwikvette, MY50cal, Phessor and 4 others like this.
  11. Apr 8, 2022 at 2:55 PM
    #251
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    It was fun before, I expect it to be even more so when it's running again. And it looks 100 times better now!
  12. Apr 8, 2022 at 2:56 PM
    #252
    Phessor
    It's looking good
  13. Apr 8, 2022 at 3:02 PM
    #253
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Those new wheels are a million times better.
  14. Apr 8, 2022 at 3:05 PM
    #254
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yes they are! Visually and size wise. No more over stretched tires.
    Kwikvette and jubei[QUOTED] like this.
  15. Apr 8, 2022 at 11:11 PM
    #255
    Kofe513
    Kofe513 Member
    Kolby
    Looks so much better without the silver, nice work!
  16. Apr 9, 2022 at 9:13 PM
    #256
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Started prepping some of the mechanical things that I can today.
    Got the Radium fuel rails and Aluminati rail adapters setup with the Radium dampers installed on the rails. Had to grind off a little material from the Aluminati adapters to clean the pulse dampers. Left the injectors off for now so they don't get messed up while I wait for the motor.
    Trimmed the "lip" off the hole for the crank damper. I'll be running a Fluidamper that doesn't have a recess for the lip. Wiped the timing covers down with Cerakote trim coating when i was done to freshen them up.
    Then I installed the Torque Solutions uppipe and downpipe blankets.
    Kwikvette, Phessor, jubei and 3 others like this.
  17. Apr 9, 2022 at 9:20 PM
    #257
    MGMDesertTaco
    Nice work on the rattle can paint. That's some tedious and labor intensive stuff with all the prep and cure times.
  18. Apr 9, 2022 at 9:34 PM
    #258
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks! Yes it is, I'm very much over it for the moment.
    MGMDesertTaco[QUOTED] likes this.
  19. Apr 11, 2022 at 7:49 AM
    #259
    jdmjustin
    jdmjustin Well-Known Member
    Justin
    SW MO
    2018 BBP Tacoma Sport
    Motegi MR149 17x8.5 Falken Wildpeak 265/70/17 Toytec Aluma 2.0
    Nice work on the safety wire on the blankets, reminds me of the ole Army days. Updates looking great!
  20. Apr 11, 2022 at 10:27 AM
    #260
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks. Lots of practice doing safety wire on motorcycles for track days and racing. Probably not to spec but it works for the intended use.
    jdmjustin[QUOTED] likes this.
