2006 Subie STI rebuild
Discussion in 'Other Builds' started by xtremewlr, Aug 6, 2021.
  1. Apr 11, 2022 at 11:15 AM
    #261
    Kwikvette
    Fresno County
    4 run, 2 don't
    Wow, that's the nicest blanket I've seen on a hot pipe holy shit.
    xtremewlr[QUOTED][OP] likes this.
  2. Apr 11, 2022 at 11:45 AM
    #262
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Sweet sweet build.
    I’ll see it one day. Still have your laptop with the tech stream need to get it down there or TW express it to ya.
    xtremewlr[OP] likes this.
  3. Apr 11, 2022 at 11:52 AM
    #263
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Thanks. They are mainly for heat protection for the shit that is around them. The up-pipe is real close to the passenger head and frame rail. There are brake lines running on the frame rail there and also power steering lines and electrical. Down pipe has less shit around it and more space but the blanket covers the part right of the back of the turbo, where it's hottest. So that will help control under hood temps and keep things safe around it as well. Turbo will also be getting a blanket, once I have the turbo. I prefer the blankets over actual header wrap. They fit looser and are thicker so should offer more heat protection for other components and be better at resisting trapped moisture, hopefully.
  4. Apr 11, 2022 at 11:53 AM
    #264
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Maybe once I have it running and the break-in done with final tuning, I can do a shake down run up to Flag.
  5. Apr 11, 2022 at 12:22 PM
    #265
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    And hopefully my Tacoma will be on its shake down run also. Getting close. . .
  6. Apr 11, 2022 at 12:23 PM
    #266
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I've seen! It's looking damn good, helluva transformation so far.
  7. Apr 15, 2022 at 1:52 PM
    #267
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Just got word that the heads are done and the turbo is in. Engine build pics and major progress coming soon!
  8. Apr 15, 2022 at 2:54 PM
    #268
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    :bananadance:
  9. Apr 15, 2022 at 4:39 PM
    #269
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Fun things to come. Engine build is happening next week sometime, which means I will hopefully be installing it the following weekend!
    Blouch Dominator 3.5XT-R 10cm^2 Turbo
    And the new, OEM heads with "light" porting (per the machine shop) and GSC beehive springs and titanium retainers with stock size GSC stainless valves.
    Front sight, jubei, Phessor and 3 others like this.
  10. Apr 16, 2022 at 10:45 PM
    #270
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    More little things in preparation for the motor.
    New power steering lines installed. Went with the IAG braided pressure line and a new return line from Rock Auto that I put more of the DEI heat sleeve on, over the heat shield that came with it. Just to match the sleeves on the AOS.
    Then I drilled the hole for the AEM sensor for speed density in one of the lower IC pipes and welded that up. Several hours later, after I finished welding, I realized I put the bung into the wrong pipe. Oops! New bung ordered so I'll have to redo that once I have it. I'll have to plug this one up.
    Then it was on to mocking up the Cobb air box and cutting the hole for the IC pipe to pass thru.
    Finally, I trimmed the intake scoop that bolts to the radiator shroud and plastic welded a plate to it to try and direct the airflow from that into the air box.
  11. Apr 17, 2022 at 1:03 AM
    #271
    4x4_Taco
    4x4_Taco Well-Known Member
    FL
    Silver SR5 4x4
    Just read through this whole thread, awesome job so far! really makes me miss my 06 Wrx I had. These cars are a blast to drive
  12. Apr 22, 2022 at 9:34 PM
    #272
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Excitement is building now!
    I light of the recent announcement by Cobb, my tuning is switching gears and will be done with Haltech now.
    Picked up a new battery for the car. Might as well since new engine.
    Received and yet to be installed the new shift boot, ebrake boot and console lid cover from Zealous Interiors.
    And finally, we have a long block! I forgot to get a pic of the full long block but will have that later. Spent the day with the tuner and we got the heads installed. Monday, they will get the measurements for the required cam buckets.
    ARP 625+ head studs.
    Ready for some head.
    Passenger side done and torqued down.
    Quick peak under the dress and the internals of the V3 long rod block from Outfront.
    Front sight, jubei, Phessor and 4 others like this.
  13. Apr 22, 2022 at 9:38 PM
    #273
    Kwikvette
    Fresno County
    4 run, 2 don't
    This threads gonna get shut down from all that porn :drool:
    Rezkid, jubei and xtremewlr[OP] like this.
  14. Apr 22, 2022 at 9:41 PM
    #274
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    The good stuff is finally getting started! :bananadance:
  15. Apr 22, 2022 at 9:56 PM
    #275
    Kwikvette
    Fresno County
    4 run, 2 don't
    I missed it but, how big is the new turbo and what are your power goals?
    Tuning for 91-93 only?
  16. Apr 22, 2022 at 10:00 PM
    #276
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Turbo is a Blouch Dominator 3.5 XT-R ball bearing turbo. Good for up to 580-600hp. We are shooting for 400+ wheel hp on 91 pump gas. E85 is not part of the picture since it is way too scarce around these parts and in SoCal. But it will be flex fuel capable.
    gfxguy and Kwikvette[QUOTED] like this.
  17. Apr 22, 2022 at 10:36 PM
    #277
    MGMDesertTaco
    What's the news/deal with the Cobb to Haltech switch? Emissions software compliance?
  18. Apr 22, 2022 at 10:46 PM
    #278
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Cobb announced Thursday? that they are discontinuing the ability to remove CELs for removed emissions equipment on all cars using their tuner. This has a huge effect on all Subie and Nissan owners that tune their cars with Cobb. Enough CELs and it will put certain cars into limp mode. The biggest change is that they are no longer supporting flex fuel tuning. So to run E85, you will have to run 2 different maps, one for pump gas and one for E85. You won't be able to tune for flex fuel which makes map changes for the higher ethanol content on the fly.
    I'm running a cat but most other emissions items on the engine are removed with this build so running a Cobb would require spending more money and changing everything to get things working right. The Haltech resolves all those issues and gives me more options down the road if I want to change things up. Like adding E85 into the mix.
  19. Apr 22, 2022 at 10:49 PM
    #279
    MGMDesertTaco
    At least you've got a work around after all the time and resources invested into this project.
  20. Apr 24, 2022 at 4:23 PM
    #280
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Popped the Haltech in. Super easy to install since it's plug and play. Obviously it still needs the tune for the car but it's ready to go. There's a perfect opening under the dash that you can tuck the ECU into, just adding some filler foam to the back of it. No need to remove carpet or anything to dig it out now for tuning, just slide it out and it rests on the passenger floor.
    And today, I got the new brake lines installed and bled the system.
    strider98, Kwikvette, Phessor and 3 others like this.
