2006 Subie STI rebuild
Discussion in 'Other Builds' started by xtremewlr, Aug 6, 2021.
  1. Sep 16, 2022 at 9:51 AM
    #301
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Finished running the oil cooler lines this morning. Just have to finish wiring in the wideband for the Haltech (no gauge tho) and then start the break-in and tuning. We have about 3 heat cycles on the initial break-in already. So yeah, the car is running!
    I'll have better pics this evening, these are pics my buddy sent me.
    RockiesTaco, jubei, Phessor and 6 others like this.
  2. Sep 17, 2022 at 9:17 AM
    #302
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    First street drive done. Nothing crazy, still not tuned. Mainly just around the block to make sure everything is working and that we have no leaks or oddities. DCCD is still broken, has been since I got the car and even after replacing both console switches and the NPS, which were some of the error codes I pulled back when I first got the car. Something we will work on after dyno tuning. I've got FreeSSM to troubleshoot that.
    Dyno tuning starts next week, with several "breaks" for oil/filter changes. Not tuning for E yet, just 91 pump gas for now. E will come sometime in October/November. My guess is around 420 WHP on 91.
    I did have to do some minor trimming and clearancing on the underside of the hood to make room for the oil cooler fittings. It's still pretty close in a couple spots but should be fine otherwise. I need to get some more paint from Grimmspeed to make that edge look nice again.
    Hard to tell in the pics but the oil cooler actually sits at a slight upward angle, putting the majority of it into the direct airflow of the hood scoop. We are hoping this should really help with oil temps during the hot Tucson summers.
    I used some cloth tape on the fittings coming out of the oil cooler to help protect them from rubbing on the intake. I need to get a new intake scoop and trim it as the other one I have, I managed to trim too much on top and it now looks like ass.
    Not the greatest pic but the oil cooler lines run down along side the radiator on the passenger side.
    Front O2 sensor is not getting used so I removed that and plugged the hole. This also helped creating more room for the sandwich plate and cooler lines. We also removed the OEM oil cooler because adding the sandwich plate to that put the oil filter too close to the the Killer B headers, making it difficult to remove and prone to major heat soak.
    Installed a new BOV flange on one of the original IC pipes. There are only 2 new pipes in the system, on the hot side going through the Cobb intake box. We played mix and match with the old pipes to find this one and only had to add the flange to it. Can't really see it in the pic but the wideband wire harness runs into the cabin through the same hole I used for the ProSport gauges.
    I've also got JD Customs bumper quick releases to install still. - https://jdcustomsusa.com/collection...r-quick-release-kit-2006-2007-impreza-wrx-sti
    RockiesTaco, jubei, uurx and 6 others like this.
  3. Sep 19, 2022 at 8:25 PM
    #303
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  4. Sep 19, 2022 at 10:27 PM
    #304
    MGMDesertTaco
    425hp/400tq? :popcorn:
    xtremewlr[OP] likes this.
  5. Sep 19, 2022 at 10:35 PM
    #305
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Pretty damn close!
  6. Sep 19, 2022 at 10:36 PM
    #306
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  7. Sep 20, 2022 at 5:53 AM
    #307
    strider98
    strider98 Rather Large Member
    2018 Taco DCSB SR5 V6
    bupkis
    Always loved that sound
  8. Sep 20, 2022 at 5:56 AM
    #308
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Damn. It's going to be so fun.
  9. Sep 20, 2022 at 7:26 AM
    #309
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    So. When you bringing it to race my mr2?
    xtremewlr[QUOTED][OP] likes this.
  10. Sep 20, 2022 at 7:57 AM
    #310
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    April/May? After it's cold and before it's hot. Also after the rust is done in Indiana.
    Kilo Charlie likes this.
  11. Sep 20, 2022 at 8:01 AM
    #311
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The rust is never done
  12. Sep 21, 2022 at 7:22 AM
    #312
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Got the front bumper reinstalled with the quick release buttons, did another oil/filter change after the Monday and Tuesday dyno sessions and then got the undertray installed. From there, we took the car out for some street tuning and 3rd/4th gear pulls to get it dialed in some more. So nice to be driving the car again! I forgot how much I enjoy driving the car, it just drives damn nice. Still at the shop today to fix the AC but otherwise, it's ready to come home now. I'll get some updated pics once I get the car cleaned up.
    01x4, jubei, Rezkid and 1 other person like this.
  13. Sep 24, 2022 at 3:32 PM
    #313
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Took at drive up Mt Lemmon here in Tucson this morning. Nice to get out of the heat for a bit. High 60s on the mountain and 99/100 here at my house. Car ran great, no issues. Tons of power on tap whenever I wanted or needed. I missed driving this car, it's so much fun!
    Just needs some minor tweaks to the map to adjust cold idle issues with the AC on. When the AC clutch engages, idle dips pretty low. All fixable in the map tho.
  14. Sep 24, 2022 at 3:36 PM
    #314
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
  15. Sep 25, 2022 at 5:58 AM
    #315
    01x4
    Awesome to see it out for a drive.
    The wheels look great by the way.
  16. Sep 25, 2022 at 7:11 AM
    #316
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks!
    Sasquatch3153 likes this.
  17. Sep 25, 2022 at 8:55 PM
    #317
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Titan Missile Silo site near me. Did this a while back, after I first bought the car.
    These are shortly after I first bought it
    These are from today. What a difference some work makes.
    And I discovered that my fuel level sender is only reading down to half tank. Ran out of gas on the way home. Have to pull the sending unit back out of the tank to address that so it will have to wait until mid-October.
  18. Sep 25, 2022 at 9:12 PM
    #318
    StreetsTheWay
    StreetsTheWay Well-Known Member
    Justin
    Alberta, Canada
    2020 Tacoma TRD Offroad, Cement Grey
    Nice looking STI man.
    I had to chuckle a litttle;
    Mine is an 07 USDM (in Canada) with not quite so many mods as yours...
    Once I get more done on the Tacoma, I need to finish working on the 03 WRX Wagon in the garage and get to doing rings and throw out bearing on the STI.
    That said, I caught myself doing some mental gymnastics - if you're going as far as taking the engine and transmission out, you might as well upgrade all the internals, intake, turbo, up-pipe, down pipe, flywheel, clutch, suspension, and a tune...
    Tis but a slippery slope.
    Jerry311SD and xtremewlr[OP] like this.
  19. Sep 25, 2022 at 9:31 PM
    #319
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks!
    You ain't kidding.... :facepalm:
  20. Nov 3, 2023 at 8:45 PM
    #320
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Been a while. Finally got around to adding E85. Tuned for it today as well as cleaning up the original 91 tune.
    Here's where it's sitting on 91 pump gas.
    E85 sensor installed.
    Smokey out the tailpipe because it's over powering the AOS. So we unplugged it after this vid.
    This is where we stopped. Only 77% injector duty cycle, so there's more there but this is more than good enough for the street. It also over powered the clutch in 4th gear on a street pull, so I might need to replace the clutch with something stronger.
