2006 Tacoma 16x7 steel wheels - backspacing and offset?
Discussion in 'Wheels & Tires' started by thomez, Mar 2, 2010.
  1. Mar 2, 2010 at 6:56 PM
    thomez
    thomez [OP] Member
    ZackN
    NE Ohio
    98 4Runner
    Looking to replace my 16" alloys on my 98 4Runner with some steel wheels (tired of the air leaks) and found a set of 06 Prerunner 16x7 wheels here on the forum for sale. Just making sure the offset and backspacing is not going to give me any trouble.
    If they are going to stick out a tad wider than my stock wheels that would actually be preferred, as I have had a slight rub when the suspension is compressed since the last tire purchase (Yokohama Geolander AT 265/75/16)
    My current backspacing (3rd gen 4Runner/1st gen Tacoma, 3 split spoke alloys) is supposedly 4.625" (4 5/8")
    Any info appreciated.
    Thanks
  2. Mar 3, 2010 at 12:04 PM
    thomez
    thomez [OP] Member
    ZackN
    NE Ohio
    98 4Runner
    falling off the first page already :(
    help would be great if anyone knows! can also be added to the sticky in this forum
  3. Mar 3, 2010 at 12:18 PM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2014 MGM Double Cab
    2016 TRD Suspension upgrade, 1st gen TRD Wheels, 265/75/16 Cooper RTX
    I did some searching here and I think they are 5.5" backspacing.
  4. Mar 3, 2010 at 8:49 PM
    thomez
    thomez [OP] Member
    ZackN
    NE Ohio
    98 4Runner
    that means they will stick inward almost an extra inch right?
  5. Mar 4, 2010 at 6:28 AM
    FL Forester
    Tallahassee, FL
    2014 MGM Double Cab
  6. Mar 4, 2010 at 5:36 PM
    thomez
    thomez [OP] Member
    ZackN
    NE Ohio
    98 4Runner
    thank you
    wheels are on the way, should be fine as long as I don't buy tires that are super wide
    you might want to add the info to the sticky in this forum since it isn't there
    thanks again
