2006 Tacoma 1GR-FE Engine Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sikruis, Jan 14, 2025.
  1. Mar 7, 2025 at 10:49 AM
    #181
    sikruis
    sikruis [OP] Well-Known Member
    Scott
    2006 Tacoma Off Road
    All of the O2 sensors?
  2. Mar 7, 2025 at 10:49 AM
    #182
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, those too.
  3. Mar 7, 2025 at 10:50 AM
    #183
    sikruis
    Scott
    The two A/F sensors and the O2 sensors? Sorry, just making sure I'm tracking?
  4. Mar 7, 2025 at 10:51 AM
    #184
    TnShooter
    Deogee
    STOCK
    Yes.
    sikruis[QUOTED][OP] likes this.
  5. Mar 7, 2025 at 11:55 AM
    #185
    sikruis
    Scott
    So with all four sensors disconnected, I received the errors after continuing to rev the engine to kept it going.
  6. Mar 7, 2025 at 4:11 PM
    #186
    TnShooter
    Deogee
    STOCK
    I can kind of see how those codes would be caused by the sensors.
    Not sure how why the knock sensor circuit is “high”?
    But who knows.
    Not concerned with misfires.
    I could see a misfire throw a knock code.
    But not a circuit code.
    More thinking to do here.
  7. Mar 8, 2025 at 5:43 AM
    #187
    mynameisbs
    mynameisbs Active Member
    Central Alabama
    2009 TRD Off Road
    I'm sorry, I have nothing I can add here but now I'm invested. Bump!
    Torspd likes this.
  8. Mar 8, 2025 at 12:44 PM
    #188
    sikruis
    Scott
    so after reconnecting all of the sensors, and disconnecting the battery for 20 minutes or so, I’m now getting the following codes: P300, P303, P304.
  9. Mar 8, 2025 at 12:54 PM
    #189
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Miss fire codes. Should be easy to check. OEM to replace if you hadn’t already. Maybe just a loose plug to them?
  10. Mar 9, 2025 at 8:06 AM
    #190
    sikruis
    Scott
    I swapped the #3 with #1 plug, the P303 code went away. I also inspected and cleaned all plugs. I’m gonna buy new plugs and see what happens.
    dk_crew, MarX[QUOTED] and RDAP like this.
  11. Mar 9, 2025 at 9:02 AM
    #191
    RDAP
    RDAP Active Member
    2016 Tacoma TRD sport manual
    Just posting to say good luck man. Everything here is well above me but I do know what it's like to have a truck not run and not figure out why. Keep at it I'm sure you'll get there with all the guys helping out. Then you'll have a running truck and know alot more about it.
    Pibbles99 and sikruis[OP] like this.
  12. Mar 9, 2025 at 9:12 AM
    #192
    TnShooter
    Deogee
    STOCK
    This whole thing just keeps getting weirder. So you swapped the plugs and 303 went away?
    What about 304?
  13. Mar 9, 2025 at 9:27 AM
    #193
    sikruis
    Scott
    I replaced all of the plugs and the codes are still coming up. Maybe I need to trace the wires for these. It is still shutting off. I am going to disconnect the battery and take a break. Maybe resetting the ECU will help.
  14. Mar 9, 2025 at 9:49 AM
    #194
    sikruis
    Scott
    No joy. Still getting P303 & 304 misfire on cylinders 3 & 4.
  15. Mar 9, 2025 at 10:33 AM
    #195
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Double check, and make sure all of your sensors are plugged back together securely.
    sikruis[OP] likes this.
  16. Mar 9, 2025 at 10:49 AM
    #196
    sikruis
    Scott
    Connections are secure.
  17. Mar 9, 2025 at 11:15 AM
    #197
    sikruis
    Scott
    I swapped #4 & #6 coils and now I’m getting misfires on cylinders #5 & #6. Feel like I’m plying wack-a-mole.
  18. Mar 9, 2025 at 3:50 PM
    #198
    TnShooter
    Deogee
    STOCK
    When I swap coils to test them.
    I like to switch them to the other bank (side) of the engine.
    Swap #6 coil with #1.
  19. Mar 9, 2025 at 3:51 PM
    #199
    sikruis
    Scott
    Good advice sir! I’ll try it tomorrow.
    TnShooter[QUOTED] likes this.
  20. Mar 9, 2025 at 3:54 PM
    #200
    TnShooter
    Deogee
    STOCK
    The coils on the mid-2000 Fords were always going bad.
    If you swapped coils on the same bank with 2 cylinder right beside each other, you could get a misfire on the cylinder beside it.
    Even though the coil wasn't really bad.
