2006 Tacoma 1GR-FE Engine Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sikruis, Jan 14, 2025.
  1. Feb 24, 2025 at 9:00 AM
    #81
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just spit balling. Since the vacuum hoses were reinstalled incorrectly, something else has to be.
    I do know a common accident, when doing an engine swap, is to also have the WRAF sensor plugs and/or the O2 sensor plugs installed on the opposite bank. Which makes it run like crap.
    @BassAckwards , didn't you encounter this on your V6? If so, do you remember how the engine acted?
    BassAckwards and Dm93 like this.
  2. Feb 24, 2025 at 10:29 AM
    #82
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I guess it's possible for the AFR/O2 sensors to get swapped but if that was the case it wouldn't affect it until it goes into closed loop which is around 30-60 seconds after startup.
    Might look at the cam sensors though it would be fairly easy to swap those connectors although I would think it would set a code.
    Torspd[QUOTED] and BassAckwards like this.
  3. Feb 24, 2025 at 11:39 AM
    #83
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yes i had an issue where the rear o2 harnesses got swapped after a clutch change. The ecu didnt know what the hell was going on and it was affecting the rear o2 voltages. Iirc it was driving up the voltages on each side to try and get a response from the sensor. I had no drivability issues, but it constantly threw codes p0136 and p0137, p0156, p0157 and an occaisonal p219B.
    @Dm93 helped me do some trouble shooting and after the wiring turned out to be good, thats when i found the harnesses swapped.
    Torspd[QUOTED] and Dm93 like this.
  4. Feb 24, 2025 at 11:46 AM
    #84
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ah yea I vaguely remember that now, that was fun lol.
    BassAckwards[QUOTED] and Torspd like this.
  5. Feb 24, 2025 at 2:54 PM
    #85
    BassAckwards
    Lol wiring is my favorite… thank god for folks like you who are good at troubleshooting
    Torspd and Dm93[QUOTED] like this.
  6. Feb 24, 2025 at 3:58 PM
    #86
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do we know that the throttle body is working properly, and if the original MAF was swapped back in?
  7. Feb 24, 2025 at 3:59 PM
    #87
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Electrical/driveability diag is my favorite thing providing it's not an intermittent issue, those suck.
    Doing it over the internet can be a real challenge though.
    Torspd and BassAckwards[QUOTED] like this.
  8. Feb 24, 2025 at 4:23 PM
    #88
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Even more challenging when you don't know what you are working with.....
    Half way through the diag when things don't make sense, and then you find out "stuff" was added.
    I'm a visual guy. I like to see what I'm working with.....
  9. Feb 24, 2025 at 5:19 PM
    #89
    BassAckwards
    If you understand how things work, I can see how it would be really rewarding trouble shooting/solving problems. I get a little overwhelmed when it comes to wiring, so I try to avoid it if I can. Like most automotive things though, it’s intimidating if you’ve never done it before and is less so once you’ve got a little experience under your belt.
    Dm93[QUOTED] likes this.
  10. Feb 24, 2025 at 8:40 PM
    #90
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Oh it absolutely is, sometimes half the battle is digging around in service info for a good description and operation.
    Once you get good at reading wiring diagrams you can infer alot about how something works even without having a description and operation.
    Yea it took me years to get where I am but I've always had an interest in electronics and it seems to come naturally to me but I wasn't always good at it.
    BassAckwards[QUOTED] likes this.
  11. Mar 1, 2025 at 10:11 AM
    #91
    sikruis
    sikruis [OP] Well-Known Member
    Scott
    2006 Tacoma Off Road
    Still have the issue of where it'll start and, if I feather the throttle, it'll continue to run but soon dies if I don't. I've checked all the wiring, fuel pump resistor, and hoses. I've got no codes and no errors.
  12. Mar 1, 2025 at 1:02 PM
    #92
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How long have you been able to get it to run while feathering the throttle?
  13. Mar 1, 2025 at 1:09 PM
    #93
    sikruis
    Scott
    Good 20-30 secs. Prob longer if I keep feathering it.
  14. Mar 1, 2025 at 1:22 PM
    #94
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am curious if you could get it to run long enough to get up to normal operating temp.? See if then that it'll set a code.
  15. Mar 1, 2025 at 1:32 PM
    #95
    sikruis
    Scott
    I was able to keep it running for a little over a min. Never got a code. I do smell my catalytic converters and wonder if I have a plugged exhaust, keeping in mind the old engine had a head gasket failure.
  16. Mar 1, 2025 at 2:04 PM
    #96
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You didn't happen to put some crap injectors off Amazon/ebay in it did you?
    I was just scrolling back through this and I noticed the coils are new but I can't tell if they are Densos or not, that got me wondering...
    #96
  17. Mar 1, 2025 at 2:38 PM
    #97
    sikruis
    Scott
    Same injectors that came with the swapped engine. New coils and plugs are OEM.
  18. Mar 1, 2025 at 2:50 PM
    #98
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That may very well be your issue, I never use injectors from a used engine. I always keep everything that was original to the truck especially if it was running, you don't know what your getting with a used engine unless you could hear it run.
    Torspd likes this.
  19. Mar 1, 2025 at 2:52 PM
    #99
    sikruis
    Scott
    Wouldn’t you expect misfires or error codes?
  20. Mar 1, 2025 at 4:48 PM
    #100
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am super curious if there is something wrong with your TB.
