2006 Tacoma 1GR-FE Engine Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sikruis, Jan 14, 2025.
  1. Mar 1, 2025 at 4:49 PM
    #101
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Or even vacuum hose routings on the passenger.
  2. Mar 1, 2025 at 4:49 PM
    #102
    sikruis
    sikruis [OP] Well-Known Member
    Scott
    2006 Tacoma Off Road
    Throttle body?
  3. Mar 1, 2025 at 4:50 PM
    #103
    sikruis
    Scott
    I’ve been looking for a good diagram. Know a good one?
  4. Mar 1, 2025 at 4:52 PM
    #104
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes
  5. Mar 1, 2025 at 4:54 PM
    #105
    sikruis
    Scott
    How would I know? I do have one from the swapped engine.
  6. Mar 1, 2025 at 7:40 PM
    #106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Try it.
  7. Mar 1, 2025 at 7:52 PM
    #107
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Super simple on the 2005-2011 trucks.
    Here's mine. 2007
    Torspd likes this.
  8. Mar 2, 2025 at 8:55 AM
    #108
    sikruis
    Scott
  9. Mar 2, 2025 at 8:58 AM
    #109
    sikruis
    Scott
    I tried it, did not have an effect.
    Torspd[QUOTED] likes this.
  10. Mar 2, 2025 at 9:37 AM
    #110
    sikruis
    Scott
    so far, I have changed out the throttlebody, disconnected the catalyst from the exhaust system. None of which have made a difference.
  11. Mar 2, 2025 at 9:53 AM
    #111
    TnShooter
    Deogee
    STOCK
    What year model is the donor engine?
    I guess I can look at the diagrams and see if there was a change in wiring at some point.
    But that's about all I can contribute at this point.
  12. Mar 2, 2025 at 10:36 AM
    #112
    sikruis
    Scott
  13. Mar 2, 2025 at 10:43 AM
    #113
    sikruis
    Scott
  14. Mar 2, 2025 at 11:38 AM
    #114
    sikruis
    Scott
    After my second pressure test, it never got below 40 psi. It's still dying. Could it be the fuel rail or injectors?
  15. Mar 2, 2025 at 12:08 PM
    #115
    sikruis
    Scott
    2007 Taco
  16. Mar 2, 2025 at 9:35 PM
    #116
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Check all the wiring. Unplug and plug in again. I wonder if the crankshaft position sensor wire isn’t plugged in all the way. That sucker is hard to get to. Just a thought.
  17. Mar 2, 2025 at 9:39 PM
    #117
    henryp
    Henry
    Montana
    Shouldn’t be an issue with the wiring I don’t think. I have an ‘09 taco with ‘13 engine. Exhaust manifolds were different but that was corrected with using truck year exhaust gaskets on the new engine. I think it has to do with install. Some wire is not connected right or vacuum leak as was mentioned.
    Torspd likes this.
  18. Mar 3, 2025 at 4:17 AM
    #118
    sikruis
    Scott
    I'm checking wires. Where should I look for a vacuum leak?
  19. Mar 3, 2025 at 5:00 AM
    #119
    sikruis
    Scott
    Say it could be a wiring issue, is there a diagnostics I can run to better help pinpoint? I have a code reader with the live data option.
  20. Mar 3, 2025 at 5:53 AM
    #120
    henryp
    Henry
    Montana
    Using the service manual (it’s free online via bootleg or pay for techstream), go through every step making sure everything was installed properly. Check the electrical connectors for corrosion or loose pins. Check all the ground connections for good contact (make sure wires are not rusted out, lots of YouTube vids on this). ECU assumes installation is correct so the codes might not be helpful.
