2006 Tacoma, 6 spd - Loose/Sloopy shifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ARamsey, Dec 6, 2010.
  1. Dec 6, 2010 at 8:11 AM
    ARamsey
    ARamsey [OP] New Member
    Alex
    Sorry if this has been covered before, I tried searching and there is alot of DIY stuff out there which I am not interesting in.
    I have a 2006 Tacoma, 6 speed manual and the shifting has become very sloppy and loose. Its also very loose when in gear. I am guessing it is some sort of worn out rubber bushing? Anyone have this issue/know the problem?
    Any idea on the ballpark cost of this repair at a local shop? Also is this something that would be covered under warranty? My car is still covered just dont want to bring it to toyota if they dont cover this type of repair
    Thanks for the help
  2. Dec 7, 2010 at 6:19 AM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    The internal bushings in the shifter has worn out. I rebuild these for $120 exchange. I also cut the shifter down about 1 1/2" for shorter shifting. When I repair these, I replace the soft rubber bushings with a polyurethane epoxy. This give a very precise shift (much firmer than stock). The only bad side is it will transmit a little more noise at Wide Open Throttle.
    This is compatible with URD short shifter (if you have one).
    You can swap this out in about 30 minutes. This is a very easy install.
  3. Dec 7, 2010 at 7:34 AM
    ARamsey
    Alex
    Do you know if this is covered under warranty?. (I dont have an aftermarket shifter)
  4. Dec 7, 2010 at 7:36 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Sorry, I do not know. It should be.
  5. Mar 7, 2011 at 5:59 AM
    darkstar85
    darkstar85 Member
    Hawthorne CA
    2012 DCLB SPORT 4X4
    20% tint Plasti dip badges, 5100/885x LR UCAs
    I just started experiencing this exact problem on my 06 with 50k miles. How did you end up fixing the problem?
    Did you go with Coupe's fix? It sounds like a nice repair.
    thanks
