2006 TACOMA access cab, TRD Off Road
Discussion in 'Audio & Video' started by flyingmanx, Mar 22, 2014.
  1. Mar 22, 2014 at 6:12 PM
    flyingmanx
    flyingmanx [OP] Active Member
    Ken
    Hi guys;
    Great forum here.
    After a week of searching and reading I started to tackle my Pioneer AVH-X3600BHS HU.
    I have the 6 speed standard model.
    I got the bypass switch figured out, radio in and working.
    iPod Classic for my tunes.
    iPhone works great.
    I capped off the extra orange/black wire, and hooked up the orange/white wires. works like a charm.
    Only thing I forgot was the Steering wheel interface, Thought I could do without it...but that ain't going to happen. Now I have to remove the radio again!!!
    my question is the back up cam reverse wire.
    I read all the posts, but am still unsure if that wire into the Pioneer need +12vDC or does it ground to operate the screen.
    I am powering the cam separately, just do not want to put 12vDC to the radio if it is not the case.
    I even found the red/wt wire. Does that wire actually go to the back up lights or a relay first??
    Just trying to be cautious.
  2. Mar 23, 2014 at 11:01 AM
    flyingmanx
    Ken
    Ok;
    So I figured it out.
    I turned on the radio, went to settings and when I got to backup cam..It said you could choose from ground or battery for trigger.
    So I crossed my fingers and figuring it was a Pioneer input, it would not hurt to ground it!!!
    Camera worked.. So then I switched the setup. Then powered it with 12VDC and works like a charm!!!!
    I think I will hook it up so reverse will trigger it, but put in a switch for when I am hooking up my trailer.
    Now my only problem is that the BOYO plate mount camera says..do not get wet???? Or use car wash??? What kind of crap is this??
    Oh well.
  3. Mar 23, 2014 at 11:58 AM
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    Looks good!
  4. Mar 28, 2014 at 1:14 PM
    flyingmanx
    Ken
    Well finally I have my radio installation complete.
    I waited for all my parts before taking the radio back out.
    PIONEER AVH-X3600BHS
    METRA DASH KIT
    AVH-X BRAKE BYPASS RELAY KIT
    BOYO Plate mounted back up cam with dash mount control wheel
    AXXESS ASWC-1 Steering Wheel Control Interface
    USB & AUX OUT run to glove box
    IPOD CLASSIC 80GB STORAGE..mounted in my glove box
    I wasn't going to do the SWC.. but 3 days without it changed my mind!
    I still have to tie in to the red/white reverse wire for the cam.
    I was hoping to get a SPDT switch that would mount in my dash spaces.
    It would be nice to have the option to leave the cam on while connecting the trailer. I just don't want to cut dash to install aftermarket switch.
    Seems Toyota does not offer a SPDT switch ( would be way too much $$$ anyway )
    Using my friends lift in a heated garage was a great treat for running the back up cam wire.
    Any questions just ask!!!!
  5. Apr 11, 2014 at 1:19 PM
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    looks pretty slick! I just ordered almost all of the same stuff, except for an appradio 3. I got the black dash kit too and seeing your pic makes me glad I did. I will be *hopefully* tying into my stock back up came and trying to get video feed from it.
    I have seen a lot of people have trouble installing their aswc-1. How'd the install go for you? And did you have to program it at all?
  6. Apr 12, 2014 at 3:38 AM
    flyingmanx
    Ken
  7. Mar 4, 2015 at 8:53 AM
    jds0912
    jds0912 Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
  8. Mar 5, 2015 at 4:20 PM
    flyingmanx
    Ken
    Mine got trashed when they gave my 2006 TACOMA a new frame, so I bought this one..VTL275HDL
