2006 Tacoma Bed is lopsided? Anyone else?
Discussion in 'Suspension' started by Rocket, Sep 23, 2011.
  1. Sep 23, 2011 at 11:55 PM
    Rocket
    Rocket [OP] Well-Known Member
    Rocket
    Campbell Ca.
    06 Taco Pre Stnd Cab
    Donahoe front Suspension. Fox nitro rear. 33" BFG's.
    Hi, I have a 2006 Tacoma Reg Cab w/25K miles on it and the bed of the truck is crooked and driving me crazy. I have Fox Nitro shocks on the back with the 3 leaf springs. People behind sometimes pull up and inform me that the bed of my truck is sagging on Drivers Side. 1 shop said its because the Gas Tank is on the Drivers side and its normal, no worries. Other shop said the drivers side leaf springs may be weak. I haven't carried anything in the bed except for 2 dirt bikes. I bought a set of AAL to add but I'd like to see what is causing the bed to sag on the left before I install the extra leaf springs. Anyone else have this problem or know how or what I can check to see what it might be?? Any suggestions would be greatly appreciated.
    Thanks ....Rocket
    ps. Fox Nitro with stock leaf springs on the back and Donahue set up on the front.
  2. Sep 24, 2011 at 12:10 AM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    idk exactly know what you’r talking about. maybe get a pic? but i do know some guys have that call taco lean. leans 1” to 2” to drivers side. it’s because they have the gas tank battery and driver all on the same side. i personally do NOT see this on my ’07 dbl cab short bed TRD off road. it has 30’700 miles.
    edit: and usually it’s the hole truck that leans not just the bed.
  3. Sep 24, 2011 at 12:26 AM
    Rocket
    Rocket
    Campbell Ca.
    Yeah, I have just the bed tilting down to the left about 2inchs. If you stand behind the truck bed, you can see the back portion of the truck is about 2 inch lower than the right side. The front of the truck looks level, cab section look level but the left rear tailgate looks lower than the right side.
  4. Sep 24, 2011 at 12:26 AM
    Rocket
    Rocket
    Campbell Ca.
    I'll post pics tomorrow. Thanks.
  5. Sep 26, 2011 at 11:26 PM
    LYNDENO
    LYNDENO Member
    riverside
    05 preRrunner
    icon 2.5 with resi,all pro 3in. leaf pack ,flowmaster 40 series,35 watt hid 6000k,kicker L7 10,kenwood 1000w amp,
    same thing with mine I think its the gas tank because it verys with how full my tank is im thinking about geting adjustable shocks
  6. Sep 26, 2011 at 11:27 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Maybe you have a broken leaf on the driver's side .
  7. Oct 5, 2011 at 6:23 PM
    litewatefitr
    litewatefitr Member
    09 trd dbl cab
    mine does the same damn thing!!!! except on mine, it's as though the passenger side of the bed is lower. it's an '09 trd offroad, double cab with 35,000 miles on it. it's making me insane! i took it to two different dealers, and even had the district parts manager from toyota look at it and all said the same thing:"it's within factory specs..." that's all well and good, but considering how damn expensive these things are, it's not within my specs. i mean, SOMETHING has to be causing it to lean like that, but nobody can tell me what it is, only that it's within factory specs and not bad enough to fix. somebody PLEASE tell me you know what the hell is going on... nobody here seems to care enough to let me know. thanks!!!
  8. Oct 5, 2011 at 6:30 PM
    litewatefitr
    litewatefitr Member
    09 trd dbl cab
    p.s., i checked my driveway with a level and it's completely level. but i can see it on any surface, including from across a parking lot. i just don't get it man...
  9. Oct 10, 2011 at 11:40 PM
    06yoda
    06yoda Well-Known Member
    Tanner
    Point Loma, CA/ Emmett, ID
    1996 Landcruiser FZJ80
    I don't know but I have OME Dakars in the back and my is 1/4" lower on the Driver side just like yours is and even that is noticeable. Still trying to dial in my suspension though. My coilovers up front are starting to really make me mad. I wish I would have bought the ext. travel Icons instead of Fox. G/L
  10. Oct 11, 2011 at 3:25 PM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    I'm a 1/4" low on the pass. side drives me crazy. I have a pro comp 3" lift so I know it's not the factory parts. Before the lift I was about an inch low on drivers side w/ a full tank of gas. I am thinking of getting the rear TSB done and keeping my aal's. I don't know if that will make me high in the rear though. Right now I have about 1/2" rake in the front wich I like. But the factory leaf pack sux. I am hoping the rear tsb plus my aal's will level out the back without making it higher??? but dunno
  11. Oct 11, 2011 at 5:46 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Lives: Fountain, Colorado/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    most of the beds on these trucks are a little croooked. i found out mine was when i got my ATO rear bumper and Kevin pointed it out to me. he said u can loosen the bed bolts and wiggle the bed around a little and it should level out. just make sure u square everything back up when u tighten the bolts down
