2006 Tacoma durability question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steve02, Dec 2, 2018.
  1. Dec 2, 2018 at 8:41 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Good point, the 1GR-FE is extremely sensitive. Turbo is on my bucket list for this truck, but I expect I'll probably blow the engine doing so at some point. But I'll just swap it. Don't think OP is wanting to get that far into it.
    OP, your 16, my advice, you can get some good 3" lift coils, ext travel struts, shocks and AAL from Dobinson's or OME for under $1,000. Buy some tools, install them yourself, learn about your truck and have fun doing it. If you love your Tacoma you will! Promise :) New 33' tires ( I highly recommend AMP off-road tires!!!), and new wheels for about another $2,500 depending on which wheels you select.
    Max $3,500. Done. Enjoy the truck.
  2. Dec 2, 2018 at 8:54 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    What wheels and tires are on it Now? Pic would help. Spacers... Not recommend, plus the $300+ to buy them could be better used to put towards new tires and wheels that would stick out more and get you the look your wanting :)
    If you decide you are going to go the spacer route, just buy some quality spacers. Not EBay $50 spacers. Because of spindle lift, I had to put spacers in the back. Currently using Spider's, no issues.
    MurderedTacoV2 likes this.
  3. Dec 2, 2018 at 8:56 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Definetely do all the installs yourself. It makes you one with your vehicle and teaches you a ton of stuff along the way. Driveway installs can be a pain sometimes but just take your time. If you can get a lift for a day to work on it then do so, your body will thank you later lol. Front struts can be removed and installed on a taco in legit 5 minutes. Its the rears that will make you do fancy stuff for them to come out. And with the wheel spacers if you DO go that route ALWAYS go hubcentric, do not spend 50$ for 4 on ebay! Look into spidertrax or something and be mindful of tire to suspension clearance with different wheel offsets.
  4. Dec 2, 2018 at 8:57 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    We said the same thing on wheel spacers lmao
  5. Dec 2, 2018 at 9:02 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Front struts in 5 minutes??? What's your secret bro, lol! Takes me like 30 minutes!!!
    Rear's, about 5 minutes each, if your having trouble with the rears, simple fix, just adjust the lift/jack to remove the tension on the bottom bolt. Will come out smooth as silk (unless it seized into the shock, that's totally duff story, lol)
  6. Dec 3, 2018 at 7:57 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    If the frame was recently replaced it should be easy to replace the suspension.
    Modifying vehicles is always lost money. It doesn’t raise the value of the vehicle and insurance will not pay for loss without ryders.
    Any truck could be a total loss tomorrow, even brand new ones. If the truck was maintained well I would expect 400k miles without major issues. But lifts tires and turbos will speed up the time it takes to encounter problems.
    I would just enjoy the truck for now and not get caught up in blowing thousands on this vehicle when you don’t have a license.
    Worry about funding college or other important life expenses.
    Sorry about your dad.
    mperl and Shwaa like this.
  7. Dec 3, 2018 at 8:46 AM
    Steve02
    Steve02 [OP] Well-Known Member
    Maryland
    2006 Tacoma SR5 V6
    Bone stock... for now
    The stock tires are on now and I don’t know a thing about the tire sizes or offset. What is the biggest tire offset I could get that would give me that look without having to cut or get suspension upgrades
  8. Dec 3, 2018 at 9:12 AM
    Steve02
    Maryland
    2006 Tacoma SR5 V6
    Thank you all so even if I didn’t get a whole suspension kit maybe fox shocks would be nice for the ride and wheels most likely with hubcentric.
    lmao my dad is fine he is just getting a brand new TRD PRO and I’m getting his old one. I wanted him to get a raptor so I could have the OG taco but he likes them so much, what can I say they are awesome trucks.
  9. Dec 3, 2018 at 9:17 AM
    PackCon
    Connor
    You said you inherited a truck from him.
    So really you mean you were given a truck.
    Muddinfun likes this.
  10. Dec 3, 2018 at 10:01 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    I have an 06 and i think the biggest thing that failed on me so far was my transfer case wouldn't come out of 4wd, so replaced with a low mileage unit. and i've got 265k on it and just did Spring under axle and Long Travel... so when something fails i will replace it as it comes....and yeah modding trucks is addictive...
  11. Dec 3, 2018 at 10:39 AM
    Steve02
    Maryland
    2006 Tacoma SR5 V6
    Yes I mispoke lol
  12. Dec 3, 2018 at 10:50 AM
    Steve02
    Maryland
    2006 Tacoma SR5 V6
    i make it a point to my father that we should replace fluids every once in a while and I rarely use 4 wheels drive even in snowy conditions but most definitely things will go bad. The altinator went bad about 60k mikes ago and also the truck now is making a chirping sound at a little under 600rpm and I think it is the power steering pump so that will be something I look at.
  13. Dec 3, 2018 at 10:56 AM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    The secret is a lift and air/electric tools plus one or two wrenchs. We started suspensions in my T-TEN class at school and hes like "alright you get the taco Adam" literally 5 mins later i had both of them on the table, guy nearly shit bricks :rofl:
    For the rears i cut a slit into it with a cutoff wheel and held it with a 8mm wrench and spun the nut off with a ratchet :anonymous: dont judge my new england rusty bolt hackwork. (obviously this was on my truck not a customers or something!)
  14. Dec 3, 2018 at 10:58 AM
    Steve02
    Maryland
    2006 Tacoma SR5 V6
    creative I will get there eventually I need to get a real job and possible start my little side business again to save up for lift and such
  15. Dec 3, 2018 at 1:14 PM
    #35
    Clearwater Bill
    Billy
    Largo Florida
    Stop.
    b_r_o likes this.
  16. Dec 3, 2018 at 1:38 PM
    #36
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I can't advise you on the turbo. But on the lift, it will put a strain on the U-joints and other driveline components. So at the very least, I suggest replacing the U-joints.
    Yes oversize wheels/tires and especially wheel spacers will stress the wheel bearings and axles, ball joints, etc.
    Also consider upgrading your brakes if you go oversize tires.
  17. Dec 3, 2018 at 4:06 PM
    #37
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    3" lift isn't bad. Specifically ensure that you get strong leaf springs in the rear to counteract axle wrap. Forget the turbo, the 2nd Gen has more than enough power.
  18. Dec 3, 2018 at 10:03 PM
    #38
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Agree,I personally would not invest any money in your 2006,way to many miles,and you will never get anything for any money put into the truck.
  19. Dec 3, 2018 at 10:24 PM
    #39
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you want to have a fun truck to wheel in stick to suspension/tire mods for now. Turbos sound like fun but they can lead to expensive problems that weren't there before. Then you can't go wheeling because your truck is in your driveway and you're looking for a motor
  20. Dec 4, 2018 at 8:34 AM
    #40
    Steve02
    Maryland
    2006 Tacoma SR5 V6
    Anyone out there with an Ls swapped taco? I mean i could make a custom exhaust charge pipe if i turbo`d this engine and if i get an Ls, or different motor, i could run my turbo on the replacement motor and wouldn't have wasted hundreds on manifolds.
