2006 Tacoma Newbie Needs Help
Discussion in '5 Lug' started by Bach, Jan 11, 2011.
  1. Jan 11, 2011 at 10:53 AM
    Bach
    Bach [OP] New Member
    daniel
    texas
    06 prerunner
    I just bought an 06 Tacoma 4dr Prerunner and would like to upgrade my stock wheels and tires to some 16x8 Pro Comp 1069's. I found some on CL off of a jeep with 4' backspacing. I dont even know what the hell that means! Do I need to make any adjustments? Thanks for yall's help!
  2. Jan 11, 2011 at 11:01 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    back spacing is to set the wheels further from the hubs. " Makes the wheel and tire stick out further.
  3. Jan 11, 2011 at 12:29 PM
    comiesutra
    comiesutra Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
    this is the calculator i like to use when dreaming about new wheels to go with my new tires
    http://www.rimsntires.com/rt_specs.jsp
    it gives a great deal of information and what to look for in case of rubbing and fender clearance
  4. Jan 19, 2011 at 12:29 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Some Jeeps have 6 lugs but most are 5 lugs. If you have a Tacoma Prerunner, you have a 6 lug and chances are they will not fit. 4 inch backspacing should be enough to clear assuming you aren't running giant tires.
  5. Feb 23, 2011 at 2:17 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    Move this thread to 6 lug tacoma's!
