2006 Tacoma rear axle bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brooky816, Sep 6, 2020.
  1. Sep 6, 2020 at 4:08 PM
    Brooky816
    Brooky816 [OP] Well-Known Member
    06 Tacoma SR5 Prerunner double cab
    None
    Need to remove axle bearing on 1 side of axle and I don’t have a bearing puller.Anybody
    know someway to remove without puller? Thanks
  2. Sep 6, 2020 at 4:16 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 tacoma doublecab 4wd trd w/e locker Pyrite mica color
    TW 1-piece driveshaft All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 2" stock springs Falken Wildpeak A/T3W 265/70R16 Powerstop rotors and z36 pads Rebuilt rear and all wheel bearings front /rear Denso 130A rebuilt alternator New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Rhino front guard ARE shell
    Rears are pressed on the axle so have to pull axle and get a machine shop to do it - do both sides at the same time as if one goes other soon to follow.
  3. Sep 6, 2020 at 4:17 PM
    Muddinfun
    Muddinfun Well-Known Member
    TnShooter likes this.
  4. Sep 6, 2020 at 5:38 PM
    Brooky816
    None
    Thanks guys. I had already pulled R side off and replaced only the bearing seal.The seal from factory had a gouge in it and
    thought that was the problem. The bearing looked fine to me and my friend but I’m no mechanic.We put it back and 3 months later
    it’s leaking a little bit behind the brake pads? I don’t know if it’s the bearing or hub assembly.
  5. Sep 6, 2020 at 5:40 PM
    TnShooter
    TnShooter Well-Known Member
    07' TRD Off-Road, Auto
    STOCK
    Yeah, PULL the bearing.
    Do NOT press the axle.
    This is one job I’ll be paying someone to do.
    I don’t have the time, or want to risk messing up other stuff.
  6. Sep 6, 2020 at 5:41 PM
    TnShooter
    STOCK
    Check your diff breather, if it’s stuck closed, it will blow the seal out.
    Mine did this and I didn’t enjoy the experience.
    ToyotaDriver likes this.
  7. Sep 6, 2020 at 5:42 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
  8. Sep 6, 2020 at 5:44 PM
    ToyotaDriver
    Idaho
    I’d also recommend looking at and upgrading the rear diff breather. It’s in a horrible spot and needs to rerouted to a higher position at the very minimum even on a perfectly stock pavement pounder.
  9. Sep 6, 2020 at 6:07 PM
    Brooky816
    None
    Does my truck have diff breather? It’s just a 2wd. That would be great if that was all it i. Like I said
    Seal was gouged from factory and bearing looked good and had no play in it.
  10. Sep 6, 2020 at 6:12 PM
    Brooky816
    None
    I guess if it’s clogged it could have blown my new seal out.
  11. Sep 6, 2020 at 6:28 PM
    Brooky816
    None
    Yeah, I got 1.
  12. Sep 7, 2020 at 4:49 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 300+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
  13. Sep 7, 2020 at 1:13 PM
    Brooky816
    None
    Thanks man way away from Mass. Down South Alabama.I will have to take to local transmission shop or
    Dealership I can trust. I really don’t want to do a dealership.Its hard around here to find trustworthy mechanics.
  14. Sep 7, 2020 at 4:39 PM
    Larzzzz
    Larry
    MA
    Bummer. Good luck.
