2006 Tacoma rear drums
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brooky816, Feb 7, 2020.
  1. Feb 8, 2020 at 9:15 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you don't make the initial adjustment after a rear brake job, then it's you that isn't doing the job properly. This isn't a judgement call. Improperly adjusted rear brakes causes weak brakes all around due to excessive slave cylinder movement.
    More importantly it could also cause the slave cylinder pistons to come out of the cylinder and a loss of all brakes from fluid loss.
    I never said that the adjuster is stuck directly after a brake job.
    What I said was this:
    " Sometimes they get stuck with dust and crud from driving off road, you will need to manually adjust them then also."
  2. Feb 8, 2020 at 9:29 PM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    Hey Brooky. Something I've learned, not sure if it's been mentioned here. IF you decide that you need new drums, it's way better to get your original drums turned if you can, as opposed to replacing them with new 'cheap' replacements. It has to do with the quality of the steel.
    DG92071 and Jimmyh like this.
  3. Feb 9, 2020 at 2:56 AM
    DG92071
    DG92071 Well-Known Member
    You are hilarious!! Thank you for this one.
  4. Feb 9, 2020 at 3:21 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    Tacoma rear drums DO NOT adjust by going in reverse and slamming on the brakes, even the ebrake. They self adjust by simply just using the ebrake when parking
  5. Feb 9, 2020 at 3:44 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
  6. Feb 9, 2020 at 4:41 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You're not worth my time...............
  7. Feb 9, 2020 at 9:19 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    Amazing how my dealership would say after my 5,000 mile servicing that my rear pads are "getting close" to replacing along with drums after 60,000 miles? When I finally started my own maintenance @ 75,000 miles I had to beat my rusted drums and use the metric bolt method to remove them since they were frozen/rusted. Guaranteed drums were never in removed in 6 years of dealership servicing! And a independent shop told me the same @ 70,000 mile service. Neither will ever touch my truck again.
    Drums are great with no grooving or marks. Still @ 10.0 diameter (256mm or 10.07 is max dia.). Shoes still have lots of life left in them. When I did 95,000 mile service last week drums came off with little to no effort. Hate to be lied to.
    EdgemanVA and XSplicer62 like this.
  8. Feb 9, 2020 at 10:44 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Drum brakes really do last a long time. Mechanically speaking, there's just a lot of surface area there, so they don't wear that fast. Of course, there are always a few exceptions but this is about what mine looked like on my old T100 after about 125,000 miles. And I always use my parking brake if it's above 20 degrees, so I'm confident they've stayed adjusted. I should probably check my Tacoma some day. My front pads will need replaced in the next few months.
  9. Feb 9, 2020 at 10:57 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I completely rebuilt my rear end last summer due to 3rd member gasket seepage and mileage being 175k. Wheel bearings, wheel cylinders, axle seals, shoes, drums, 3rd member gasket, new brake hardware....everything except pinion seal - it wasn't leaking and can do that by undoing 4 bolts & dropping shaft. Anyway, back to topic here...shoes still had about 1/2 the thickness of new ones at this mileage but drums were worn too far to turn. Went back with everything oem and hope to get same mileage use from it. Only on 2nd set of oem disc pads up front and those have plenty left. Will go with new rotors next time pads need attention.
  10. Feb 9, 2020 at 1:37 PM
    Brooky816
    Brooky816 [OP] Well-Known Member
    06 Tacoma SR5 Prerunner double cab
    None
    Thanks for all the advise!
  11. Feb 9, 2020 at 3:41 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2 and I would not trust what I'm told with out checking it myself - I've found they are just trying to sell you something you don't need - not always but a lot of the time.
    EdgemanVA[QUOTED] and wags like this.
  12. Feb 10, 2020 at 9:02 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I won't debate this, but I only install new drums or rotors for a reason- they're warped or out of the thickness spec. So I generally replace pads and shoes and that's it. And I've never had an issue. If they aren't scored or warped, and in the thickness limit they get reused. Another justification for changing parts unnecessarily is that you work at a shop and want to run up the bill.
    Lester Lugnut likes this.
  13. Feb 10, 2020 at 9:30 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Hopefully I learned my lesson with that one. I went online as soon as I arrived home and ordered a new set of Toyota brake shoes because I wanted to have everything in hand before I started.
    My state inspection is next month, so I'll probably pop off the drums on each side and re-grease the mating surfaces. I know the shoes are in great shape...lol
