2006 Turbo Puddle Jumper
Discussion in '2nd Gen. Builds (2005-2015)' started by MrCrowntown, Oct 16, 2016.
  1. Dec 28, 2017 at 5:01 PM
    #541
    MrCrowntown
    MrCrowntown [OP] Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Haha, wait til my full dream is actualized. It will be an attention getter fo sho :cool:
    ChadsPride likes this.
  2. Dec 31, 2017 at 1:35 PM
    #542
    ChadsPride
    Sponsored by TacomaWorld.com
    Happy New Year brother!!!
    :cheers:
    MrCrowntown[OP] likes this.
  3. Dec 31, 2017 at 6:51 PM
    #543
    MrCrowntown
    Alyn
    Ky
    Happy new year buddy!
    To boost!!
    yota243 and ChadsPride like this.
  4. Dec 31, 2017 at 6:52 PM
    #544
    ChadsPride
    To boost!!! :proposetoast:
  5. Dec 31, 2017 at 6:56 PM
    #545
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    U gettin dat rav4 boost game on fleak this year?
    ChadsPride[QUOTED] likes this.
  6. Dec 31, 2017 at 6:58 PM
    #546
    ChadsPride
    Lol, have to pay that sucker off before it can happen.
    By that time it will be my DD :) and perfectly acceptable to stuff some things under the hood
  7. Dec 31, 2017 at 7:02 PM
    #547
    yota243
    E.J.
    north Alabama
    Wait? Which hood? 2.5 or 4.0?
  8. Dec 31, 2017 at 7:03 PM
    #548
    ChadsPride
    2.5 :oops:
    Plan to make the Rav my DD/sleeper and get the wife a 4r
    yota243[QUOTED] likes this.
  9. Dec 31, 2017 at 7:06 PM
    #549
    yota243
    E.J.
    north Alabama
    :bananadance::transformer:
  10. Dec 31, 2017 at 7:07 PM
    #550
    ChadsPride
    :devil: :D
  11. Jan 2, 2018 at 3:11 AM
    #551
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I'm in, for helping wrench.
  12. Jan 2, 2018 at 3:31 AM
    #552
    ChadsPride
    That'd be most appreciated! :fistbump:
  13. Jan 2, 2018 at 9:22 AM
    #553
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Subbed! Do you have an auto or the 5spd? and if the manual, which clutch are you running?
    MrCrowntown[OP] and ChadsPride like this.
  14. Jan 2, 2018 at 10:38 AM
    #554
    MrCrowntown
    Alyn
    Ky
    5speed, and will be upgrading to the LCE metallic clutch. It will be my first venture into a performance clutch on this truck! The OEM clutch has done me well, but I assume I will burn it up super fast after the turbo install lol
  15. Jan 2, 2018 at 11:11 AM
    #555
    BassAckwards
    Nice! I have also been considering this for whenever I s/c my 2.7. I was between the LCE Pro kit, and the metallic clutch and I'm thinking ill go with the metallic one since the URD s/c I'm planning on puts out 248rwhp (which will be closer to 300 at the crank and that is on the upper limit of the LCE Pro). Please let me know what you think about the clutch whenever you get it installed! I'm curious as to how harsh the release point/pedal feel will be. Either way, I'm almost 100% sure this is the one I'm going with since once I put some headers and an exhaust on it, it will more than likely be over the 300hp that the LCE pro will support. I just recently (about 25k miles ago) put a new OEM clutch in there and its looking like ill have to upgrade it again, so I'm really trying to avoid having to change it out again after I upgrade it and supercharge it.
    How soon will the turbo be getting installed? and how much boost do you plan on running through your 2TR?
  16. Jan 2, 2018 at 12:37 PM
    #556
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Ill make you a manifold
    5 Lug Fury, ChadsPride and yota243 like this.
  17. Jan 2, 2018 at 1:20 PM
    #557
    MrCrowntown
    Alyn
    Ky
    Well, to start i will be putting no more than 10psi into the stock block. But that should get me to around 300ish anyhow.
    That should be happening at the end of jan, or in feb. SO EXCITE! Then it's time to start building the forged block for real power!
    I think the metallic is going to be a bit rough on takeoff, and I will be DDing this for a while, so theres a distinct possibility I go with the Dual Comp clutch. 385hp rated, same clamping force as the metallic clutch too... but only 385 supposedly, but I dont know if they are under, or over rated
  18. Jan 2, 2018 at 1:22 PM
    #558
    MrCrowntown
    Alyn
    Ky
    You will be receiving a PM when I start my Forged build :fistbump:
    5 Lug Fury and ChadsPride like this.
  19. Jan 2, 2018 at 2:05 PM
    #559
    BassAckwards
    Thanks a bunch, I will probably end up going with the Dual comp LCE like you mentioned. Sounds like a good balance of a stiffer pedal/higher hp & torque rating while still maintaining decent drivability. I'm glad I asked you about this. I didn't even see this option when cruising on their website and looking at things
    This is the one you were referring to right?
    http://www.lceperformance.com/Dual-Comp-Clutch-Kit-2TR-2005-2014-10-p/1053085.htm
  20. Jan 2, 2018 at 2:32 PM
    #560
    MrCrowntown
    Alyn
    Ky
    Exactly! Have you ever replaced your clutch before? If you have already gone one, I would get their optional hardware as well. Preventative at the least!
