2006 Turbo Puddle Jumper
Discussion in '2nd Gen. Builds (2005-2015)' started by MrCrowntown, Oct 16, 2016.
  1. Jan 2, 2018 at 2:39 PM
    #561
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I had mine replaced once at 200k miles by one of my friends at a Toyota dealership, but I didn't do it myself. Whenever I upgrade to the LCE ill probably just pay to have a member from on here do it. I don't have any experience working on transmissions, and murphy's law typically holds true for me lol. I'll definitely get the optional bolts for the flywheel and pressure plate though. Are they just stronger than the OEM ones? or what purpose do they serve?
    ChadsPride likes this.
  2. Jan 2, 2018 at 3:32 PM
    #562
    MrCrowntown
    MrCrowntown [OP] Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I believe they are OEM, but even so, with the added forces expected, you want bolts that have only been stretched once, rather than re torqued. ARP hardware would always be best, but I don't know the answer to that one yet :D
  3. Jan 2, 2018 at 4:12 PM
    #563
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Cool if you have another cylinder head that would be sick. If not father in law has a 07 4 cyl taco I could use for building the manifold.
  4. Jan 2, 2018 at 4:18 PM
    #564
    MrCrowntown
    Alyn
    Ky
    I actually do have a spare hahaha
  5. Jan 2, 2018 at 4:18 PM
    #565
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Brah, his work looks alright just sayin, prolly fabbed once or twice
  6. Jan 2, 2018 at 4:20 PM
    #566
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Personally I'd like to have the turbo also so I can clock it all properly height in engine bay etc.
  7. Jan 2, 2018 at 4:21 PM
    #567
    MrCrowntown
    Alyn
    Ky
    Have any experience with intake manifolds? The one I have is from thailand, and its slapped together.
  8. Jan 2, 2018 at 4:24 PM
    #568
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I don't to be honest but I'm sure I could.
  9. Jan 2, 2018 at 5:12 PM
    #569
    SLVRNBLK
    SLVRNBLK Well-Known Member
    Ozzie
    Lithia, FL
    Silver TT
  10. Jan 2, 2018 at 5:31 PM
    #570
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Could always use my truck for the prototype. If I ever get this long travel finished, I'll be starting the turbo build after that.
  11. Jan 2, 2018 at 5:58 PM
    #571
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    That pressure plate feels like stock. Feels great.
  12. Jan 2, 2018 at 6:07 PM
    #572
    BassAckwards
    Noicee! You running this pressure plate with the turbo setup on your truck? Thats what i was hoping for as i daily my truck every once in a while
  13. Jan 2, 2018 at 6:18 PM
    #573
    MadTaco461
    CA
    Kinda stock
    I'm running that pressure plate. You can easily use this pressure plate as a DD. It's surprisingly light and predictable.
  14. Jan 2, 2018 at 6:32 PM
    #574
    BassAckwards
    Thanks again! Sounds like a perfect fit for my uses. I appreciate the feedback:hattip:
  15. Jan 12, 2018 at 3:55 PM
    #575
    MrCrowntown
    Alyn
    Ky
    Time for resealing the Timing cover!
    Will be doing it tomorrow, possibly with @XPOTRPR !
    XPOTRPR and MadTaco461 like this.
  16. Jan 12, 2018 at 4:38 PM
    #576
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did it on a co-worker's the other day. Someone asked if it was a Harvey truck. Lol!
    We were lazy and just coated the outside known leaking area. That and a new front main seal, and no more rust preventative on the frame.
    MrCrowntown[OP] likes this.
  17. Jan 12, 2018 at 4:41 PM
    #577
    MrCrowntown
    Alyn
    Ky
    Yeah, this one will be more involved than that
    gotta pull the sub pan and the timing cover lol
    I dont want it to leak when the turbo is on.
  18. Jan 12, 2018 at 4:48 PM
    #578
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Putting in a turbo drain fitting also?
  19. Jan 12, 2018 at 4:49 PM
    #579
    MrCrowntown
    Alyn
    Ky
    Thats a great Idea actually.
    Damn, what size should I put in? hmm
  20. Jan 12, 2018 at 5:01 PM
    #580
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Most people use -10AN. You can always adapt to smaller. The size of your turbo's outlet is a good indicator.
