2006 Turbo Puddle Jumper
Discussion in '2nd Gen. Builds (2005-2015)' started by MrCrowntown, Oct 16, 2016.
  1. Feb 24, 2022 at 8:08 AM
    #781
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You already have the wide band sensor, yes?
  2. Feb 24, 2022 at 11:51 PM
    #782
    MrCrowntown
    MrCrowntown [OP] Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Aem wideband for now, will probably go full haltech at some point
  3. Feb 25, 2022 at 4:38 AM
    #783
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So you are using the AEM sensor tapped into the Haltech, or using it separately from the Haltech?
  4. Feb 25, 2022 at 7:24 AM
    #784
    MrCrowntown
    Alyn
    Ky
    Tapped for reference. Although I don't know if I'm going to use it as a tuning point. It's finicky
  5. Feb 26, 2022 at 1:11 PM
    #785
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Haltech WB1 ftw
  6. Feb 26, 2022 at 2:24 PM
    #786
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This^^^
  7. Feb 27, 2022 at 5:37 PM
    #787
    MrCrowntown
    Alyn
    Ky
    My bday is next month :anonymous:
  8. Feb 27, 2022 at 7:02 PM
    #788
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which means the WB1??? Or turbos and blow? Lol. As in BOV.
    XPOTRPR likes this.
  9. Feb 27, 2022 at 11:49 PM
    #789
    MrCrowntown
    Alyn
    Ky
    Probably the wb1 lol got the other things already
    05Taco4x4 likes this.
  10. Feb 28, 2022 at 7:55 AM
    #790
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    sure.. lol
    MrCrowntown[OP] likes this.
  11. Feb 28, 2022 at 8:01 AM
    #791
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :spy:
    XPOTRPR likes this.
  12. Feb 28, 2022 at 8:24 AM
    #792
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    sometimes you just need some motivation... lol
  13. Feb 28, 2022 at 7:24 PM
    #793
    MrCrowntown
    Alyn
    Ky
    I'm going to Miami at the end of March. Plenty of motivation there :rofl:
    XPOTRPR and Torspd like this.
  14. Feb 28, 2022 at 7:57 PM
    #794
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I'm in wpb :anonymous:
  15. Mar 6, 2022 at 7:37 PM
    #795
    MrCrowntown
    Alyn
    Ky
    This trip is cancelled but good to know! I will be out there this summer :cool:
  16. Mar 7, 2022 at 10:57 PM
    #796
    MrCrowntown
    Alyn
    Ky
    I'm gonna have to take off the intake to get to my temp sensor, so im going to use this time to install my shiny Turbo manifold at the same time :cool:
    This weekend, I will have some new pics to share again... finally. Lol:bananadead:
  17. May 22, 2022 at 5:54 PM
    #797
    MrCrowntown
    Alyn
    Ky
    The "weekend" finally came :D
    Test fitting my new intake!
    Yes, it's filthy. Emphasis on "test fit" ;)
    My beautiful yard workspace!
    Tapping the port in the center of the runners to M14x1.5 for the haltech intake sensor!
    Essence of filth x10000
    Intake off, more filth
    She fits! I will have to move a bunch of things permanently, but I can work on tucking the harness, moving heater core hoses, and routing fuel lines correctly.
    This is exciting, as I have been neglecting my baby.
    Inspired by @Torspd and his low key smack talk from the 2tr camshaft thread haha
    :crapstorm:
    Yota X, Torspd, 05Taco4x4 and 4 others like this.
  18. May 22, 2022 at 7:10 PM
    #798
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Glad my smack talk did some motivating. Now to actually get to working with you on a plan for the manifold........Since my crazy work schedule is about to slow down.
  19. May 22, 2022 at 7:21 PM
    #799
    MrCrowntown
    Alyn
    Ky
    That sounds like a plan :cool:
  20. Jun 21, 2022 at 8:57 AM
    #800
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Where did you get your intake manifold from? or did you build it yourself?
    Also curious if you've decided on a turbo yet or what you're going with
