2006 Turbo Puddle Jumper
Discussion in '2nd Gen. Builds (2005-2015)' started by MrCrowntown, Oct 16, 2016.
  1. Feb 6, 2017 at 2:51 PM
    #81
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Feb 6, 2017 at 2:53 PM
    #82
    MrCrowntown
    MrCrowntown [OP] Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    When they said they have an 1800 HP 3rz....
    It got me excited... Probably the main reason I went with LC !
  3. Feb 6, 2017 at 4:17 PM
    #83
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Easier swap than an LS! :dancingbacon::crapstorm::quickdraw:
    MrCrowntown[OP] likes this.
  4. Feb 6, 2017 at 4:54 PM
    #84
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Blows my mind how fast an efr turbo spools up.
  5. Feb 6, 2017 at 4:59 PM
    #85
    MrCrowntown
    Alyn
    Ky
    This
  6. Feb 6, 2017 at 5:15 PM
    #86
    MadTaco461
    CA
    Kinda stock
    But that cost. I'm thinking a gtx3071 or the efr 7064 for my truck.
  7. Feb 6, 2017 at 5:30 PM
    #87
    MrCrowntown
    Alyn
    Ky
    Im going with the twin scroll too, for better mid range boost response. I was gonna go with the 7064 but im shooting for much higher HP numbers now. I could probably go twin GTX for the price of one EFR haha
    MadTaco461[QUOTED] likes this.
  8. Feb 8, 2017 at 10:29 AM
    #88
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My BW 9180, with a 1.04 A/R T4 inlet (despite twin scroll setup), spool through the boost threshold sooner than the SMALLER Precision Turbo 6266. Which is journal bearing, .86 A/R T4 tangential inlet. By a measure of 500-800 RPMs. 1000hp turbo versus a 700
  9. Feb 8, 2017 at 4:27 PM
    #89
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    excuse me if this is a dumb question but if you put a turbo in and are essentially getting more HP to the wheels does this help with being under geared? i see a lot of built up rigs have 410s and thats what our trucks come with stock. instead of spending money on gears i think a turbo would be more fun.
  10. Feb 8, 2017 at 5:24 PM
    #90
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    It does but you should never skimp on proper gears for your tire size.
    MadTaco461 likes this.
  11. Feb 11, 2017 at 4:50 AM
    #91
    MrCrowntown
    Alyn
    Ky
    Most tacoma guys are driving a V6 and if i remember correctly, the V6 uses a 3.73 and benefit from moving to a 4.11 setup to increase torque. That would lend us to go up to a 4.30ish ratio to get the truck back in the stock powerband.
    Now, I want to be the voice of reason for you. The price of the gears and installation of the gears(if you don't install them yourself) will cost just as much as a single, new, turbocharger. After the turbo, you need exhaust manifold, injectors, blow off valve, wastegate, 1:1 rising rate fuel pressure regulator and much more.
    I am well into $10,000 worth of parts specific to the turbo build. That does include a $2,000 spare motor too though.
    I would say regear to something in the 4.30s, but not further than 4.50s. It will be worth it far sooner than a turbo kit would. :thumbsup:
    Good luck with your decision, and feel free to ask anything else you may think of
    Kees, nfs257 and tacoburrito[QUOTED] like this.
  12. Feb 11, 2017 at 6:52 AM
    #92
    tacoburrito
    boston
    2013 regular cab
  13. Feb 11, 2017 at 6:59 AM
    #93
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Holy crap man i had no idea u had that much cash dropped in ur setup. Im sitting at just under $3500 on mine for the 4.0 but i did everything myself so i have $0 in labor. Ur also gonna be able to run like 3x the boost i am i guess since ur on a load of forged internals. But i would think stock internals would handle enough to well surpass the next step in a regear for not much more than a regear front and rear if you can fab everything yourself. Heck on a 4cyl you could mostly get a manifold for about the same or less than i have on headers and all my pipe for crossover and up pipe. Then all u would have to worry with is the down pipe
  14. Feb 11, 2017 at 7:24 AM
    #94
    MrCrowntown
    Alyn
    Ky
    I very much could have went cheaper haha
    I decided very quickly, as I discovered the true strength potential of the block, that I could push it to the moon with no worries. So I invested into the idea of 1000hp+ very quickly. I grabbed a couple spare heads that I have been playing around with porting and polishing to get me some sweet CFMs too. Those and the tooling to achieve what I want are included in the total as well.
    I am sure the total will go over 20k once I get into axle upgrade and trans bulletproofing. But for the last ten years that I have had this truck for, I have dreamed of doing exactly this. Now I can afford it, and have gotten to a place mechanically and mentally that I'm ready for some sweet, sweet boost!
    :burnrubber:
    Edit: I will be doing most of the labor as well, but I cannot pass up an opportunity to be part of research and development for LCEngineering either..
    not_nick, nfs257, RedLantern and 4 others like this.
  15. Feb 11, 2017 at 7:26 AM
    #95
    MrCrowntown
    Alyn
    Ky
    You're welcome bud, glad to help anyone I can!
  16. Feb 11, 2017 at 8:03 AM
    #96
    MadTaco461
    CA
    Kinda stock
    Gears are worth it even with boost. If you add weight and large tires gears help a lot. Helps tighten your gear ratio between shifts. Plus you'll never be under 3k rpms.
  17. Feb 11, 2017 at 8:06 AM
    #97
    MrCrowntown
    Alyn
    Ky
    Thats an excellent point that I had honestly not considered yet. Since the redline will probably be extended up towords 9-10k a higher ratio would be beneficial
  18. Feb 11, 2017 at 8:13 AM
    #98
    MadTaco461
    CA
    Kinda stock
    I already want a higher rpm. 7k red line would be sweet.
  19. Feb 11, 2017 at 8:51 AM
    #99
    MrCrowntown
    Alyn
    Ky
    Snag some cams! haha
  20. Feb 12, 2017 at 12:45 AM
    #100
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
