2006 will start but wont move
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dannybten23, Jun 10, 2015.
  1. Jun 10, 2015 at 9:31 PM
    freddirt
    freddirt Well-Known Member
    Clint
    Southern Utah
    Usedtahave'21 CMNT GRY DCSB TRD OR 4x4
    Wheels: Helo HE900 17x9 -12 offset. Tires: Toyo open country AT3 265/65. JLT catch can. RSG sliders. Diff breather mod. Wheelers extended rear brake lines. LED interior lights. Front suspension: Accutune King 2.5 ext travel w/ adjusters, Icon tubular uca w/ delta joint, Wheelers super bumps. Rear suspension: Accutune Tundra 2.5 remote resi Kings w/ adjusters, Icon RXT leaf pack, U Bolt flip w/ Wheelers super bumps.
    I've had to use the super handy holes in the drum before on my '90 yota. Drum decided to weld itself to the axle. Worked like a charm... Good luck OP and hope there is no serious issues going on.
  2. Jun 11, 2015 at 1:28 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    maybe his clutch is all done???
  3. Jun 11, 2015 at 7:54 AM
    freddirt
    Clint
    Southern Utah
    Hey OP, any updates?
    Fixer5000, I dont think the clutch is the issue from his original explanation. Could be, but he said it feels like the parking brake or brakes area stuck, so I'm guessing the clutch is starting to grab but the truck wont move. Dunno though cause I'm not there, so it could be. Smoked clutches suck.
    Another thing I wanted to share that happened to me on an '85 yota I had that would be something to check real quick... Top bolt of the driver's side caliper fell out. So when I would back up and apply the brakes, the caliper would fold out and hit the rim. I would then drive forward and the caliper would go back into place. Everything was fine going forward, but when I would back up... that one wheel would lock up. Didn't take many times of that happening before I figured it out, but it was super weird.
  4. Jun 19, 2015 at 12:25 PM
    freddirt
    Clint
    Southern Utah
    OP... get your rig figured out? I'm just curious as to what the problem is/was.
  5. Jun 19, 2015 at 12:39 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Hey OP, I had the exact same issue with my 2012. Everytime I washed my truck, the driver's side rear drum would lock up. At first I could just drive forward or back and I could pop it. It got worse and would completely freeze. had to have it towed to dealership twice. The second time they had to pull everything apart and it turned out it water was not draining properly and they had to clean it out. So far no problems. I would guess same thing is happening to you.
