2006toyota v6 4.0 Leader vvt I Current in oil.
Discussion in 'New Members' started by Tacoma tag, Oct 5, 2023.
  1. Oct 5, 2023 at 8:24 AM
    Tacoma tag
    Tacoma tag [OP] New Member
    Taggert
    2006 Toyota Tacoma v6 vvti
    I've Been trying to track a coolant leak inside the engine. We tested the head gaskets and Borscope Check the oil cooler Throttle body And no leak, could it possibly be the timing chain cover? It runs really good No, miss fires or anything like that. And no oil in coolant. Or high pressure. When on any Clues to look at?
  2. Oct 6, 2023 at 6:50 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Are you certain your getting coolant in the oil and it's not just condensation?
    If it is indeed getting coolant in the oil all it can be is an oil cooler, a crack in the block, a head, or the timing cover, a timing cover seal leaking, or a headgasket.
