2007 2.7 now running rough - code P2195
Discussion in 'Technical Chat' started by rjg, Feb 27, 2012.
  1. Feb 27, 2012 at 9:17 AM
    rjg
    rjg [OP] Yes
    RJ
    PA
    2007 Regular Cab 4x4 5 Spd 2.7
    LCE header, AFE filter, Blinglight Fogs, URD Short Shifter, Delay wipers
    Hello all,
    My truck has developed a rough running condition (hesitation, surging) after letting it sit for a week. The check engine light just came on after running about 25 miles - code P2195.
    I thought I may have got some bad gas since I filled it up before parking it (drove about 50 miles on the fill up before letting the truck sit).
    Any thoughts? Just bad gas?
    Thanks for any insight!
  2. Feb 27, 2012 at 10:19 AM
    rjg
    rjg [OP] Yes
    RJ
    PA
    Is it possible that the air/fuel sensor is causing the o2 sensor code? I wonder if bad gas damaged this....:mad:
  3. Feb 27, 2012 at 10:21 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Dis-connect the battery for a few minutes and see what happens. Maybe undo the gas cap and re-install, too. I'd put some dri gas in the tank as well. Or, by the look of it you do need a new A/F sensor. images_99f9b761ab451894a06c0946e48ad1487fbea301.jpg
  4. Feb 27, 2012 at 3:55 PM
    rjg
    rjg [OP] Yes
    RJ
    PA
    Reset the CEL, however only drove 20 miles to work. Picked up some dri gas and put it in. We'll see how the ride home goes. It was still hesitating but running it at higher RPMS it was not....
  5. Feb 27, 2012 at 3:59 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Oh snap! That truck is toast just scrap it and sell me your rear 3rd member :D
    Don't know what's up with your truck..... good luck sorting it out. Maybe clean your MAF?
  6. Feb 27, 2012 at 4:07 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If it's setting a code for the A/F sensor then that's where I'd be heading. Also, look around the engine compartment for any disconnected vacuum lines or burned wiring. [​IMG]
  7. Feb 27, 2012 at 5:00 PM
    rjg
    rjg [OP] Yes
    RJ
    PA
    Thanks Steve. I checked earlier and didn't see anything burnt or unhooked. Now I had the air intake off when I put the header on. It ran fine for over 200 miles. Letting it sit in my garage for 8 days makes me wonder about the gas(after refueling). As soon as I pulled out of the garage today I noticed the idle slightly surging.
    Also I've never had a bad o2 sensor cause sputtering. I would have thought the CEL would have kicked on right away. We'll see if it comes back on the ride home.
  8. Feb 27, 2012 at 5:04 PM
    rjg
    rjg [OP] Yes
    RJ
    PA
    Thanks. I think it is time to trade;)
  9. Feb 27, 2012 at 6:06 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Nah its a great truck. Probably a dirty sensor.
  10. Feb 28, 2012 at 6:25 AM
    rjg
    rjg [OP] Yes
    RJ
    PA
    The light came back on last night. I noticed the truck ran somewhat smooth at cold start up - 30 degrees. So it seems the A/F sensor is causin the problem.
    A trip to the dealer is in order - still under the 12/12K warranty. Hopefully they don't try to tell me the header caused the malfunction.
  11. Feb 28, 2012 at 6:59 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
  12. Mar 7, 2012 at 11:27 PM
    rjg
    rjg [OP] Yes
    RJ
    PA
    Got the A/F sensor replaced today under warranty. No questions asked about the header. It's running excellent again! :)
  13. Mar 8, 2012 at 6:47 AM
    Bryan139
    NJ
    '09 Sport
    What did the paperwork say it would have cost out of pocket?
  14. Mar 8, 2012 at 7:51 AM
    rjg
    rjg [OP] Yes
    RJ
    PA
    Labor - $38.09 (which breaks down as 12.70 for the diagnostic test and 25.39 to replace)
    Part - $212.16
    tax - $ 3.00
    Total - $253.25
    Seems rather cheap for the computer fee and labor. Maybe since they do not participate in the Certified Toyota Program they can only submit a certain amount under certified warranty.:confused:
  15. Mar 8, 2012 at 11:11 AM
    Bryan139
    NJ
    '09 Sport
    That's seems super cheap. When I was talking to one of the...I guess techs? at the dealership he was very clear about $114.95 just to pull the code and they'd give me an estimate from there.
    $25 for labor means he had it changed in like 7 minutes. I'm using your mechanic for now on.
  16. Mar 8, 2012 at 11:41 AM
    rjg
    rjg [OP] Yes
    RJ
    PA
    Wow! $115 just to read the codes.... I have an OBDII reader that I got for $30 shipped off Amazon. I guess it has definitely paid for itself.
