2007 ecu
Discussion in 'Performance and Tuning' started by cmcurry123, Feb 2, 2009.
  1. Feb 2, 2009 at 9:38 PM
    cmcurry123
    cmcurry123 [OP] Active Member
    Portland, OR
    07 Tacoma SR5
    3" Revtek Spacer kit. True Flow XDI intake. Flowmaster DOS 50 Series.
    Is the ECU for an 07 Tacoma located behind the glove box still? I need to take it out to send it the JET for the ECU performance upgrade I bought. Anyone know anything about that Product and if I will see results? Thanks guys.
  2. Feb 3, 2009 at 4:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The Jet reprogramming will do nothing for your truck. Get your money back.
  3. Feb 3, 2009 at 2:49 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Dito... Your going to lose money, and possibly damage the ECU.
    If you looking for tuning, look at the APR X-1, the Map ECU 2, or the URD MAF cal for a real basic tuning unit.
  4. Feb 3, 2009 at 2:51 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    buy a URD MAF calibrator insted.
  5. Feb 3, 2009 at 5:43 PM
    cmcurry123
    Portland, OR
    07 Tacoma SR5
    Alright, good to know. Thanks guys. But I dont really know what the URD MAF is or anything about the or the APR X-1. Any info will help.
  6. Feb 3, 2009 at 5:47 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    well, go to urdusa.com and check out the plug and play devices that they have for your truck. as for the APR X-1 im not so sure what that device is. but best of luck on your modding.
  7. Feb 3, 2009 at 6:26 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    wow... thems are expensive... :eek:
  8. Feb 3, 2009 at 6:33 PM
    cmcurry123
    Portland, OR
    07 Tacoma SR5
    Yeah the controller is a bit expensive. So i am about to order the MAF CAL from urdusa.com, anyone familier with what you do with it? Im kind of new to the engine tuning upgrading. I normally stick to headers, exhaust and intake.
  9. Feb 3, 2009 at 6:47 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    well i know its got an adapter that you can plug into your laptop. But id be careful with that. if your not careful, you can really mess up your engine. but they give good instructions on how you configure it and everything.
  10. Feb 3, 2009 at 6:59 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Im about to sell my URD MAF Cali, with plug & play harness. Just FYI...
  11. Feb 3, 2009 at 7:02 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    well there you go. an opportunity :D
  12. Feb 3, 2009 at 7:07 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    When might you be interested in selling? If the op doesn't go for it, may be interested.
  13. Feb 3, 2009 at 9:15 PM
    roxspin72
    NC
    Oh Yeah!!!
    Got one PM from a member, they got first dib. You are second. Read PM...
  14. Feb 4, 2009 at 9:57 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    The saying "You get what you pay for" is dead on with the X-1. While it is a bit pricey, it will do EVERYTHING, and was designed specifically for the 1GRFE motor/ECU.
    It is one the best bang for your buck when it comes to HP gains. Only way to gain more power is by forced induction.
    http://aprpower.com/indexX1.html
    And for those that saw my 3rd gear pull, and notice my 1/4 mile times in my sig. Couldn't have done that without the X-1.
  15. Feb 4, 2009 at 11:42 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    very nice. know anything for the 2TR-Fe??
  16. Feb 6, 2009 at 9:50 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    URD has all kinds of real tuning options for your Toyota truck.
    We know these trucks and know the tuning devices well. No one will be better at the tech support you need.
    I am sure that Toyota dealer can sell you an X-1, but are they ready to help you will any installation or other issues you may have? Can they walk you through turning on the launch control, or give you a custom map that you can load with a plug in USB drive?
    Yes, we have tuning options for the 2TR-FE engine. I was driving around in one last night working on a special project, a URD SUPERCHARGER KIT!!!
    For starters we have the URD MAF Sensor Calibrator with maps that we can preload for the stock intake or the K&N Series 63 intake.
    We also have the MAP-ECU2 that is loaded with more features and gives you full timing control.
    If any of you need any help with getting more out of your truck with a good tune give me a call 877-8URDUSA x3 and we can go over the different options and help you decide which is best for you and your truck.
    Stay way from those "sticker tuners"!
    Gadget
  17. Feb 6, 2009 at 9:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2!
  18. Feb 6, 2009 at 1:32 PM
    roxspin72
    NC
    Oh Yeah!!!
    The Man has spoken:D
    URD Rocks. I would not tune my truck with out them backing that product.
    Keep up the good work URD...
  19. Feb 6, 2009 at 1:38 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    oh yeah i know you guys rock. i bought my jardine catback from you guys. i love it. i may buy some headers from you guys as well.
