2007 Pre-runner tire question (double cab)
Discussion in 'Wheels & Tires' started by KDUB, Jun 10, 2010.
  1. Jun 10, 2010 at 5:17 AM
    KDUB
    KDUB [OP] New Member
    Alabama
    07 Pre-Runner
    Leveling kit
    New member to the forum and Tacoma owner. I have added a 2.5 leveling kit and having issues with tires. I have tried 295's,285's and 275's. All scrub either the frame or rocker arm. I was going to order XD wheels and was told the largest tire I could use without some scrubbing was a 265. Was also told if I used a -12 offset on the wheel it would rub the back fender and front mud flap. I am somewhat disappointed as the 265 is the stock size and wanted a bigger tire. Any suggestions other than lifting the truck more would be appreciated.
  2. Jun 10, 2010 at 5:26 AM
    rjclemen
    rjclemen Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    you can stick a 31 under a stock suspension fine, so going to a big 32 shouldn't be a problem. If you have to trim its nothing that people can see.
  3. Jun 10, 2010 at 5:35 AM
    KDUB
    Alabama
    07 Pre-Runner
    Leveling kit
    What size tire do you recommend and what would you have to trim?
  4. Oct 17, 2010 at 3:59 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    you can fit a 265/75/16 or 265/70/17 equivalent on there w/ stock rims and be fine. you can fit wider tires on there, ie 285s on stock tires, but you will have to run spacers on the front to keep the tires from rubbing the upper control arms due to the backspacing of the stock wheels. the most common rim to run on 285s is 8" wide and running a 4.5" backspacing. once you get in the 33" range, you start getting into rubbing on the plastic inner fenders and the body mount.
