2007 Reg Cab 4X4 5 spd
Discussion in 'New Members' started by KentuckyEd, Nov 26, 2010.
  1. Nov 26, 2010 at 5:47 AM
    KentuckyEd
    KentuckyEd [OP] Member
    Ed
    Louisville, KY
    2012 std cab 4X4 2.7L auto
    Just bought my truck and registered here. It's pretty much a stripped 4X4 truck with A/C. I'd like to upgrade a bit and install intermittent wipers. If I buy the stalk switch is it just a plug and play install with all of the required wiring already in place? Or do I also have to run extra wiring? Also checking out some bucket seats to replace the bench. That seat back angle is not real comfortable on my back.
    Thanks for your input.
    KentuckyEd
  2. Nov 26, 2010 at 5:53 AM
    hogeyphenogey
    hogeyphenogey Rotted frame = New Truck!
    Dave
    Chicopee, MA
    2015 TRD Off Road Crew Cab
    new truck... No mods yet!
    welcome Ed- you'll find a great group of ppl here and a ton of mods. If you search the forums, you'll find a thread for what you're looking to do, and I believe that if I read correctly, it's plug and play for your truck. I believe I read it to be pre-wired and set up for intermittant. Click on "forum", then "2nd gen" and then on the top right should be a "search" feature. Type intermittant wipers and it should pop up. Or, you can look at the top for the "mods + tutorials" and it should be in there too.
  3. Nov 26, 2010 at 5:57 AM
    hogeyphenogey
    Dave
    Chicopee, MA
  4. Nov 26, 2010 at 6:05 AM
    KentuckyEd
    Ed
    Louisville, KY
    Thanks for your replys, I'm already searching and finding the intermittent wiper threads.
  5. Nov 26, 2010 at 11:40 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    welcome ed....theres a ton of good info on here anything ya do a search for and cant find no mattr what ya try just ask. someone will usually have the answer or a link to get ya the answer
