2007 Tacoma Prerunner 2wd Rear Diff????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by akcoma, Jan 17, 2010.
  1. Jan 17, 2010 at 11:19 AM
    akcoma
    akcoma [OP] Member
    alfredo
    Mckinney, TX
    '07 PreRunner
    I have a 2007 Tacoma DC Prerunner 2wd with a A04A rear diff and would like to know what size diff i have in my axle i.e 8"/8.4", 30 spline/27 spline etc..:confused:
    I like to do some traveling on state or national parks roads and would like the ability of travelling as far as possible with a locker similar to the Detroit TrueTrac locker,the Aussie locker or a Powetrax/Lock Right :)
    I have looked into the Aussie and Powertrax option but their catalogs does not include newer model Toyotas and when I wrote to them they told me they did not have an option for my 2007 Tacoma.
    However this diff/third member could have been used in an older model Toyota and I would really appreciate if anybody knows this information...
  2. Jan 21, 2010 at 1:02 PM
    akcoma
    akcoma [OP] Member
    alfredo
    Mckinney, TX
    '07 PreRunner
    :confused: anybody care to help???:)
  3. Jan 21, 2010 at 1:05 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Jan 21, 2010 at 1:06 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    Not really.... Just kidding bro!
    I can't help with advice but I can give a Free bump.
  5. Jan 21, 2010 at 1:23 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    SR5 and TRD sport trucks have the 8.4 diff, compatible w/ the older gen tacos. your gear ratio is 3.73 if your a V6. also the SR5 have an open diff, the sport has a LSD.
    TRD ofrroad trucks have a 8.0 diff (also compatible w/ older trucks IIRC) w/ the electronic locker.
    all the above info has been covered many times, which you would have found much sooner if you would have searched...;)
  6. Jan 21, 2010 at 1:25 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
  7. Jan 22, 2010 at 11:03 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    SR5 is just a trim package. It has nothing to do with the diff size. All of the diffs are the same size; the measure 8" but are called an 8.4. The e-locker diff has a larger bolt pattern to accommodate the e-locking mechanism, but essentially the same ring and pinion size as a regular third member.
  8. Jan 22, 2010 at 12:52 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    i know that, but an SR5 will not have a LSD or locker, which is why i labeled it that way. the OP used the common ref for the diffs, and i did the same, never said anything about the ring sizes...but good info there. OP is talking about the ability of fitting a locker and never specified what trim he had, so i was trying to cover all basis for him.
  9. Jan 22, 2010 at 12:55 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Some SR5 does have LSD.
  10. Jan 22, 2010 at 12:56 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I see your point but the trim package doesn't really matter.
  11. Jan 22, 2010 at 12:58 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    i could be mistaken, but wont admit it until i see proof? only sports come w/ the LSD...
  12. Jan 22, 2010 at 1:02 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No, the Sports come with the SR5 package. This is where the misconception comes in. You won't find a base model SR5 truck with a LSD
    True yosh, you are not mistaken
  13. Jan 22, 2010 at 5:03 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    I just traded in an '06 DC Prerunner V6 SR5, and it had an LSD rear diff.
  14. Jan 22, 2010 at 8:39 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ how do you know it was an LSD? was it listed in the window sticker, or did the salesman tell you that?
  15. Jan 23, 2010 at 11:10 AM
    akcoma
    akcoma [OP] Member
    alfredo
    Mckinney, TX
    '07 PreRunner
    :) Thank you for all the great help....just to summarize then it is a 8.4", called an 8" w/ a 30 spline.....:) (and I did the searches but all of them refer to offroad, SR5 etc which I beleive did not apply to my truck!!:D)
  16. Jan 23, 2010 at 11:11 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Backwards. Its an 8" referred to as an 8.4"
