2007 TRD P0171 lean code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Derrickm72, Nov 2, 2017.
  1. Nov 6, 2017 at 7:41 PM
    eon_blue
    Azusa, CA
    Bad spark plugs and/or wires, an exhaust leak or bad air/fuel sensor can also throw this code. I fought this code for awhile on my 04 and it turned out to be a hidden vacuum leak.
  2. Nov 6, 2017 at 9:05 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    How about updating your information. There may be someone near you that can help. Only so much can be said over a forum. We can tell you what to look for until we are blue in the face. I know there are a handful of smart guys on here.
    That, or man up and take it to a shop where guys that work on them every day would know where to look. Just my two cents.
    blu92in99 likes this.
  3. Nov 7, 2017 at 1:13 PM
    Derrickm72
    Derrickm72 [OP] Member
    Here's what I found. Under load traveling up a small hill.
    Cal. Load % = 90
    MAF = 5.2
    Fuel trims
    S1=20
    L1=39
    S2=23
    L2=39
    At warm idle I get
    Cal load% =27
    MAF = 0.5
    Fuel trims
    S1= -5
    L1= 30
    S2= -7
    L2= 31
    The only codes I get are 171 & 174 (lean on both banks). Once it starts not wanting to respond to throttle & engine starts stumbling it will not stop until it finally shuts off. Then it will fire right back up & run better for a small time. But if you shut the key off when it has started these symptoms & before it shuts down by itself, then it is very difficult to crank. I also noticed that after this has happened & u restart truck short term trim is like -17 and long term is +39. Way out of spec.
  4. Nov 7, 2017 at 3:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try unplugging the 02 sensors and just drive around like that.. I wonder if one of them is shorted out and sending a weird signal to the computer
    The calculated load at 90 going up hill means that the pcm is recognizing your request for power. That's a good sign for the maf..
    It looks like your trims (long term) are hi at idle and under load. The pcm is begging for more fuel. (If unplugging the 02 sensors doesn't help) it looks like all the sensors are recognizing a need for fuel!
    Fuel pressure and fuel quality are highly suspect. That sucking sound is likely the engine "gasping" for fuel.. I know the sound you're talking about.. I trust that you looked really hard for a vacuum leak. But actually, if you had a vacuum leak the the trims would stabilize once the throttle is cracked open. Just the fact that the trims are hi all the time makes me think about a constant lack of fuel..
  5. Nov 7, 2017 at 4:24 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @b_r_o thanks. You just put the fuel trim's in perspective for me. :thumbsup:
    @Derrickm72 do you have a fuel pressure gauge? You stated earlier that you disconnected the fuel line near the tank and let some out... Did you use the fuel pump or a siphon? I would imagine that if you used the fuel pump, it would send gas flying out of the hose. I don't know what the fuel pressure is supposed to be, but I would guess that it is up there.
  6. Nov 7, 2017 at 4:45 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    • yea, your trims are way out there. Since they are still similar on both banks it's not going to be an exhaust leak. How many miles on your truck and what kind of fuel do you put in? I'm gearing towards a fuel pump issue. Thats why its starving equally on both banks. If it was a plug, coil, anything like that it would be uneven. Because you are an 07 with probally some good miles if it was me I would immediatly put in a new PCV valve. Cheap and 5 minutes to replace. If it's clogged it could cause these issues. That or your fuel pump.
    Derrickm72[OP] likes this.
  7. Nov 7, 2017 at 4:51 PM
    Razorecko
    Gen' 2's have an intank fuel pump with a filter screen. It starts to clog after 30k miles and slowly starts to run lean. There is a reason why you gen 1' guys have 200-200k miles on your trucks and you dont see that with future gens. You have replaceable fuel filters. I threw a URD fuel pump kit with an in line filter and I change it out every 30k miles. If I dont the truck start to have a hard time cranking over.
  8. Nov 7, 2017 at 5:15 PM
    Derrickm72
    I don't currently have a fuel pressure gauge. Yes, I let fuel pump itself pump out a gallon, it did it fairly fast too.
  9. Nov 7, 2017 at 5:22 PM
    Derrickm72
    Yeah only the short term trims ever get low or negative even. And that's always around start up or after the issue occurs & I refire motor.
  10. Nov 7, 2017 at 5:27 PM
    Razorecko
    I would do the pcv valve and have your fuel pressure checked. I'm sure that your fuel pump is going out and if its not, than the filter that is in the tank unit with the pump is clogged up. Your short trims are in the " -" on startup because the truck is trying to dump fuel to richen out the mixture. But when you start driving it's just starving for fuel. I'd get it sorted asap. You will destroy your engine. Toyota codes trigger when you are already on the threshold of S.O.L
  11. Nov 7, 2017 at 5:27 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Get your hands on a fuel pressure gauge, duct tape it to the windshield and start driving! Personally I would not spend any more money on parts until I know the fuel pressure is good
  12. Nov 7, 2017 at 5:39 PM
    Razorecko
    Fuel pressure i think in the normal range is around 50-55psi / correct me if i'm wrong.
    I did forget to mention though that it is more likely that your Fuel Pressure Regulator is taking a crap before the fuel pump itself.
  13. Nov 7, 2017 at 5:55 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    buddy of mine had an issue with his car, it ran fine for a bit but once it warmed up half the engine would stall. ended up being a clogged cat lol
  14. Nov 7, 2017 at 6:03 PM
    Derrickm72
    Any1 recommend a decent priced fuel pressure kit that would have proper connections?
  15. Nov 7, 2017 at 6:21 PM
    #35
    eon_blue
    Azusa, CA
    Cat converters operating inefficiently usually throw a P0420 code...I've had to deal with that expensive disaster too lol.
  16. Nov 7, 2017 at 6:21 PM
    #36
    Razorecko
    Yea but if your buddy watched trims for both banks hes see only the bank with a bad cat was running lean. Its not impossible that both cats are shot in which case it would be a devil to track down.
  17. Nov 7, 2017 at 6:22 PM
    #37
    Razorecko
    I had the p0420 also. Got a dt-y pipe with some new rear 02's and i was golden.
  18. Nov 7, 2017 at 6:28 PM
    #38
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    fair enough, I kinda figured it would of thrown a diff code but wasn't sure haha just trying to think outside the box hahaha
    yeah this was on a crossfire not a taco, I don't even think it was throwing codes to be honest but I really don't remember cuz it was a while ago lol he bought it for a good price, really good price haha but it had been in a front end collision but all repairs were done. picked it up and on its way to its new home it stalled, spent a while in the driveway parts charging with some mechanic buddies. finally took it to a shop, put it up on the lift and the cat was bent restricting flow and after running for a while it would stall half the engine lol replaced the cat and all was good hahaha but I doubt that both cats are blocked, and like mentioned above it would throw a diff code then OP is getting.
  19. Nov 7, 2017 at 6:50 PM
    #39
    Razorecko
    Also with my ultragauge it was showing my cat code under "pending" as it was right near the threshold of triggering a cel. Which it did for one day and went back. I knew something was off because my drivers side bank fuel trims were off wack.
  20. Nov 7, 2017 at 6:52 PM
    #40
    eon_blue
    Azusa, CA
    hmm I wonder if they might be related then. P0420 doesn't always mean a bad cat, it can also be triggered by an exhaust leak...which can also trigger a P0171. Something to consider anyhow
