2007 TRD P0171 lean code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Derrickm72, Nov 2, 2017.
  1. Nov 7, 2017 at 6:59 PM
    #41
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    A false air leak into the exhaust would not upset the fuel trims enough to stall though.. 02 sensor inputs are only supplemental. They can affect only small incremental changes. The lions share of the fuel strategy (at least under load) is accomplished through the maf. We can see through the 90% calculated load that the pcm is not getting any bad/incorrect info. It sees the airflow and throttle angle when he floors the pedal but it still can't get fuel. The 02s are seeing the lack of fuel in the exhaust and driving the trims up
    A converter could be clogged and not code.. but yes, the trims would be funny one side only.
    SOSC likes this.
  2. Nov 13, 2017 at 2:13 PM
    #42
    Derrickm72
    Derrickm72 [OP] Member
    Is there a fuel pressure test port on a 07 v6? I can't find anything & I hate to splice a line. Trying to figure this shit out ppl!!
  3. Nov 13, 2017 at 4:28 PM
    #43
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I believe it's at the back of the motor where the supply line feeds the fuel rail.
  4. Nov 17, 2017 at 12:51 PM
    #44
    Derrickm72
    Unable to find a fuel pressure port of any kind. I noticed when I remove the vacuum line from the fuel pressure regulator I get no change at all in rpms. Shouldn't I get a change in them if regulator is good?
  5. Nov 17, 2017 at 3:34 PM
    #45
    Derrickm72
    Any1 plz?
  6. Dec 11, 2017 at 2:34 PM
    #46
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Did you ever get to track down the culprit?
  7. Dec 11, 2017 at 4:56 PM
    #47
    Derrickm72
    Apparently it's my fuel pump. I borrowed a pressure gauge & checked it as I drove. It would drop down to 20psi under load. Soooooooo, I'm dropping the gas tank this week & rebuilding the fuel pump- lucky me!
