2007 TRD vs. 2013 TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dragr1, Apr 12, 2013.
  1. Apr 13, 2013 at 9:39 PM
    #41
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    True
  2. Apr 14, 2013 at 4:52 AM
    #42
    dragr1
    dragr1 [OP] Well-Known Member
    Allpro bumper Warn M8000 241,000 miles
    Company is footing the bill and the company wants it stock except for someway to mount a winch. Reliability is the key and the best way to have reliability is to leave it stock. I know b/c I have had lots of modded vehicles. Double cab short bed TRD Offroad is what I will be getting and only in silver exterior-identical to what I have now. I just wanted to make sure that I could run with the atrac off in the mud.
  3. Apr 14, 2013 at 10:44 AM
    #43
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    YES... but you will simply push the button to turn it on, so you don't stay stuck.
    A-TRAC turns a single front spinning tire and a single rear spinning tire into FOUR tires that are rotation-matched to crawl you out, like a tank.
    There is so much mis-understanding and mis-representation of A-TRAC by those who either don't have it, or those who have yet to fully use it.
    The rear-locker is understood, and is the reason I select the Off Road 4WD Tacoma each year model I got one (2001, 2005, 2010). I did not know what A-TRAC was when I traded up from my '05 to the '10. I came here to TW for answers (the dealer or company literature was of no help). Then I went off road to experiment with the new traction systems... and was blown away by the differences between what my rear locked '05 4WD could do (which was amazing) and the identical 2010 did, even without the rear locked. I use the rear locker sometimes, but the A-TRAC really makes it obsolete in the various conditions I typically four wheel in...
    I posted a lot about A-TRAC and the other new systems because there was either not enough information or to counter the tons of FALSE and misleading drama posted here by the non-A-TRAC members. Sure, there is nothing better for pure traction than a front and rear locked 4WD, in most situations. However, Toyota does not offer a front locker. My enthusiasm is over STOCK traction from the factory. The one other beauty of A-TRAC (besides it comes as standard equipment on the Off Road 4WD) is you can steer with it on. Lockers inhibit tight steering often found in off road trails.
    As for the 5 foot bed... It holds as much as the first generation 6 foot bed I had before... being a bigger truck. A longer bed would not allow as much off roading, due to hang ups on a longer over-hang. A-TRAC is NOT for slippery roads, otherwise it would be on all models (VSC and TRAC are for slippery roads). A-TRAC is for severe off roading, such as steep grades, loose rocks, boulders, etc. Even my 5 ft. bed was a bit too long for some of the off roading I do... as I came down off a boulder and smashed the underside, and pulled my bumper away from the truck. A 6 foot bed would have really been hard to get through.
  4. Apr 14, 2013 at 10:48 AM
    #44
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    haha how is that relevant to what you just quoted?
    The OP just said what truck he is getting, he's good.
  5. Apr 15, 2013 at 8:58 AM
    #45
    David K
    Because of the OP's statement of wanting to be sure he could turn off A-TRAC in the mud...
    My reply was to counter the tons of 'anti-A-TRAC' propaganda that has naturally confused the OP into thinking A-TRAC turned off is somehow better!:rolleyes:
    If you are in low range 4WD, there is just no way I see that 2 wheels turning (A-TRAC OFF) is better than all 4 wheels turning (A-TRAC ON). Before A-TRAC was installed, we would have to use front and rear lockers to get that kind of traction... and Toyota doesn't offer front lockers on the Tacoma. :)
  6. Apr 15, 2013 at 10:05 AM
    #46
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I am pretty sure system never goes completely off unless somebody pulls the fuse out. :D
    Nothing makes life more interesting than truck cutting power to engine mid slippery hill climb with trailer behind you.
    :popcorn: Cant wait for Part 2 of this saga
    OP. I would take new truck for a spin with out trailer first.
  7. Apr 15, 2013 at 10:09 AM
    #47
    Brian007Taco
    Brian007Taco 007Taco
    Don't ask!
    Tempe, Arizona
    12 OR 4x4 dcsb
    12 OR 4x4 dcsb 265/75/16 KO2's wrapped on MB352's. Toytec CO's with 5100's front and back, 1/2" block and aal. Derped Emblems. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    How about the Prerunners? Do they have the atrac or the locker in the 2009+?
  8. Apr 15, 2013 at 10:11 AM
    #48
    OZ-T
    Peter North
    British Columbia
    Prerunner TRD Offroad will have a locker , no ATRAC though , that's only on '09+ TRD Offroad 4x4's
  9. Apr 15, 2013 at 10:35 AM
    #49
    Brian007Taco
    Don't ask!
    Tempe, Arizona
    12 OR 4x4 dcsb
  10. Apr 15, 2013 at 5:17 PM
    #50
    David K
    A-TRAC is only a Low Range 4WD system... for crawling up, out of, or over conditions where up to three tires can be off the ground or spinning free... and with just one tire, even a front tire, can pull you through.
    As Oz said, only on the 4WD OFF ROAD TRD TACOMA, standard since 2009. Has been on other Toyota and Lexus vehicles for more years, however.
  11. Apr 15, 2013 at 5:29 PM
    #51
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I don't understand why Atrac has a bad rep. I have only heard good things about it. And you can turn it off. You can run with a locked rear diff and enable Atrac to help the front traction.
    On an unrelated note, what kind of maintenance have you done to your 07?
  12. Apr 15, 2013 at 7:43 PM
    #52
    dragr1
    Exactly, I don't need atrac to be my "nanny"
  13. Apr 15, 2013 at 7:50 PM
    #53
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    ATRAC doesn't cut power. It applies brakes to the slipping wheel. The system is actually designed so the brakes get can still get full assist when the throttle is open. (The other Tacos lose vacuum assist when you give throttle.)
    ATRAC doesn't arm until you consciously hit the ATRAC button in the dash.
  14. Apr 15, 2013 at 7:52 PM
    #54
    dragr1
    Minimal, fluid changes, 2 sets of front brake pads, 1 rear full brake job, TSB on rear springs, 2 sets of shocks, 3 or 4 cv axles due to torn boots (never broke one), 2 bent shifter cables (sticks on logging jobs), all ujoints replaced, all control arms on front replaced-upper and lower (bushings worn so just replaced the whole arm), 2 or 3 wheel bearings, 1 blower motor, 1 leaking a/c line and refrigerant recharge. I think that's about it-which is way way less than the 3 previous Chevy 1500's that I had in the woods at work.
  15. Apr 15, 2013 at 7:53 PM
    #55
    KenLyns
    Belly of the Beast
  16. Apr 15, 2013 at 7:55 PM
    #56
    OZ-T
    Peter North
    British Columbia
    Better not get a new one then :eek:
    Ermahgerd
  17. Apr 16, 2013 at 5:22 PM
    #57
    2013TuRD
    2013TuRD Well-Known Member
    Bruce
    SW BC
    TRD OFF ROAD
    I've run in the mud with A-trac on, It doesn't do any nannying. It did help me pull into and out of the the deeper muck and go around the stuck Jeep.
  18. Apr 17, 2013 at 5:23 PM
    #58
    David K
    Wow, dragr1 and OZ-T, really? Nothing 'nanny' about traction control that works or that you can turn off. If you won't believe me... can you believe the others or the video clip above? The A-TRAC mimics a locker in the front and rear. Notice that when the front tire leaves the ground, it isn't braked to a stop but is matching the rotation of the other tire in front, giving a near 50-50 split in torque.
    Than you KenLyns for the clip! Looks like Ayers Rock in Australia, but I am sure they don't let you drive up it. It is real steep and one solid rock (I climbed it in 1970)!
    A-TRAC works great on loose rocks too... that's where I got amazed with it... and how it pulled me out of a couple places that my previous Tacomas would have required a pull!
  19. Apr 17, 2013 at 5:26 PM
    #59
    OZ-T
    Peter North
    British Columbia
    I disagree , VSC / TRAC is nanny mode , I wasn't talking about ATRAC as I have no opinion or interest in it
    In summary , I don't care about ATRAC
  20. Apr 18, 2013 at 8:36 AM
    #60
    David K
    I understand amigo... Have you tried to spin-out your truck on a wet road in 2WD, only to find that the VSC actually works at straightening out the truck, almost like you were in 4WD? I guess that was what impressed me about VSC. As for TRAC, it is very minimal in 2WD, but in 4WD (without any engine regulation) it is a big boost in traction ability as I have discovered going to the same places as I had in my '05 and '01 Tacomas. I guess I am lucky to be able to compare the old with the new in various conditions (desert, beach, rocks, snow) living where I do? Have a nice day, ok!
