2007 TRD vs. 2013 TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dragr1, Apr 12, 2013.
  1. Apr 18, 2013 at 8:39 AM
    #61
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I am not a fan of VSC in low traction ( snow ) conditions
    I guess I am lucky to have learned how to drive in snow without it
  2. Apr 18, 2013 at 2:56 PM
    #62
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    Yes, you are.
    I look at it this way. For on road driving, learning to drive without modern traction aids develops the skills needed to safely operate a vehicle fully under human control. If you drive like that with aids active, any intervention the aids take will usually be minimal. That philosophy is predicated on the aids functioning beneficially. Yes, I know. ABS sucks in snow.
    Off road (or other low traction situations), the behavior of A-TRAC and the like can't be replicated manually (braking wheels independently), so there's no human controlled analog.
  3. Apr 18, 2013 at 2:58 PM
    #63
    OZ-T
    Peter North
    British Columbia
    Once again , to summarize
    I wasn't talking about ATRAC , I don't care about ATRAC
  4. Apr 18, 2013 at 3:15 PM
    #64
    DoorDing
    Bodie, CA
    yes
    To summarize, I was speaking generally.
  5. Apr 18, 2013 at 3:43 PM
    #65
    moondeath
    moondeath Winter is Coming
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I think there is a lot of confusion going on here. ATRAC is different from TRAC. ATRAC only comes on when you push the button and are in 4lo. It doesn't cut power, it gives LSD like effects all around. You can also turn on your locker at the same time if you please. TRAC in 4lo is OFF.
  6. Apr 18, 2013 at 3:56 PM
    #66
    DoorDing
    Bodie, CA
    yes
    It's been stated several times that the traction aids can be turned off.
    It's also been stated several times that if the OP wants a factory rear locker, the only option is the Off-Road package, which includes several traction aids that can be turned off.
  7. Apr 18, 2013 at 4:47 PM
    #67
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    Myself, having a 2012 TRD Off Road, I believe in the ability of ATRAC. I do understand that this is a bone stock factory truck and ATRAC is not the best thing to happen to traction. But IMO, ATRAC is worth having and using when in a tight spot. Here is another video demonstrating ATRAC at work, very good example at 1:15 here.......
    http://www.youtube.com/watch?v=PKl30rPjsG0
  8. Apr 30, 2013 at 4:08 PM
    #68
    joeyd27
    joeyd27 Member
    2013 TRD OR
    I printed out your 9 drive modes and hit the trails today. Your right 4Hi seems different. In 4Hi going slow, I hit the VSC button and the TRAC OFF light comes on. If I hold the button for 3+ seconds then the TRAC OFF and VSC OFF lights come on.
  9. May 1, 2013 at 5:05 AM
    #69
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 2 Hella 4000 HID, 1 Cibie Halogen. Bilstein 5100s Ride Rite Air Bags
    Thanks, so what we would like to know is 4WD TRAC OFF = AUTO LSD, as it is in 2WD? Can you test on a hill climb the difference between TRAC ON and TRAC OFF. I can climb almost as easy/far in H4 with TRAC as L4. L4 is just less stressful on the truck, as you can crawl slow (A-TRAC on, naturally).
    REVIEW:
    In the 2009-2011 Tacomas, in H4 (4Hi) it is normally in traction control mode, but without engine regulation (same as AUTO LSD in H2)... and to help the confusion, Toyota called this TRAC (as they do with the 2WD TRAC which has regulation). 2009-2011 models in H4 have a choice of TRAC (no regulation) and VSC OFF (no traction control or VSC)... two modes.
    2012+ (in H4) has three modes in H4: TRAC (regulation?), TRAC OFF (no regulation?), and VSC OFF (no TRAC or VSC).
    Thanks for your help!:)
