2007 V6 4.0 liter oil change help
Discussion in 'Technical Chat' started by ronmdon, Sep 20, 2010.
  1. Sep 20, 2010 at 9:07 AM
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    First time oil do-it-yourself oil change with this truck for me.
    Issue is that after draining old oil and dumping 5 fresh quarts in the dipstick reads about 1-inch above full. When I attempt to drain oil from pan, nothing comes out....
    Steps prior to issue:
    -removed oil filter and drained catch pan bellow filter
    -replaced oil filter and filled new filter part way up with oil
    -removed oil pan plug and let drain for 20 minutes until drips stopped
    -put 5qrts of 5W-30 into 'Engine Oil' tube
    -ran truck for a few minutes
    -checked dipstick and saw that oil was 1-inch above full 'dot'
    -removed oil pan plug and nothing came out
    -waited 20 minutes, still nothing came out.
    -dipstick still reads too high
    Help would be appreciated.
  2. Sep 20, 2010 at 9:08 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Did you drain the tranny by mistake?
  3. Sep 20, 2010 at 9:12 AM
    JTaco386
    JTaco386 Well-Known Member
    JT
    Fort Rucker, AL/ Home: Port Orange, FL
    13 DCSB TRD Sport 4x4
    ^^ what he said...sometimes people mistake the 2..:eek:
  4. Sep 20, 2010 at 9:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  5. Sep 20, 2010 at 9:13 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Bro you probably drained the tyranny fluid!??
  6. Sep 20, 2010 at 9:14 AM
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    See attached photo of what I drained.
    Color was red.....
  7. Sep 20, 2010 at 9:15 AM
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    wow, well it looks like I really blew that one.
    Let me go find the read oil pan.
    What would have happened had I drove it...
  8. Sep 20, 2010 at 9:16 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yep, that's the tranny.
  9. Sep 20, 2010 at 9:16 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You would burn the tranny up.
  10. Sep 20, 2010 at 9:18 AM
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    30 miles...
  11. Sep 20, 2010 at 9:20 AM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    :eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
    Good luck dude! And I mean that in the most sincere way.:eek::eek:
  12. Sep 20, 2010 at 9:22 AM
    gunner_20
    gunner_20 ...
    Nixa MO
    03 Tundra A/C TRD Off Road 4x4
    Maybe Toyota should put a sticker on the pan for the tranny and oil. That way things like this dont happen... :eek:
  13. Sep 20, 2010 at 9:26 AM
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    well thanks all for the quick responses.
    problem has been identified and my manhood compromised in the process.
    signs of serious damage would be...
  14. Sep 20, 2010 at 9:28 AM
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
    Don't feel bad. It happens a lot. The first time I changed the oil I went right for the tranny plug but caught my mistake in time.:)
  15. Sep 20, 2010 at 9:30 AM
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    point taken lrgrnr, but everyone is a 'nooob' at one point in time.
    Here I am.
    Help forum?
  16. Sep 20, 2010 at 9:31 AM
    gunner_20
    gunner_20 ...
    Nixa MO
    cant fault a guy for trying to save some money and do it himself.
  17. Sep 20, 2010 at 9:33 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  18. Sep 20, 2010 at 9:37 AM
    Przemekmsu
    Przemekmsu Well-Known Member
    Przemek
    South Jersey
    2006 Toyota Tacoma, SR5 V6, 4x4 TRD Off Road
    K&N Air Filter, WickedFlow Exhaust muffler
    Next time ask before you do anything else to your truck, there is a lot of good threads on this site on how to do things. Most of them even involve pictures with step by step instruction. People are really helpful here and that is what makes this website so good!!!!
  19. Sep 20, 2010 at 9:37 AM
    619Tacoma
    Call me Rocco
    San Diego, CA
    I don't know what else you can do but simply make sure you have the appropriate amount of tranny fluid back in there and hope for the best. If damage was caused (which we hope isn't the case but let's be realistic) you'll start experiencing it with your tranny not shifting, gears slipping, etc.
    Also, you should probably change your engine oil again because if you DIDN'T drain the engine oil, and you put in another 5quarts, you have WAY too much oil in there.
  20. Sep 20, 2010 at 9:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No need to bash anyone over this. It has happened plenty of times in the past.
    OP, As mentioned, add what came out of your tranny back into it. Drain the engine of oil, and re fill to the correct 5.5 quarts.
