2008 Front Rotor Specs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gavonder, Aug 8, 2009.
  1. Aug 8, 2009 at 6:49 AM
    gavonder
    gavonder [OP] She's Kickass!
    Bethel, Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    The last time I had my truck serviced (30,000 mile) the dealer said I need new front pads and rotors soon, So, I ordered Hawk pads from raceshopper.com. and am doing the brakes myself.
    I thought I would measure the rotors when I got into it, because I thought 30,000 miles was pretty low for new rotors already. My rotors measure 29mm and they seem to be pretty smooth (no groves). I found specs for 2006 that say standard is 28mm - minimum is 26mm.
    Does anyone have the specs for 2008?
    Thanks,
    GA
  2. Aug 8, 2009 at 9:11 AM
    gavonder
    Bethel, Ct
    Anybody?? I'm trying to do this today.
    Thanks
    GA
  3. Aug 8, 2009 at 9:16 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I'm not sure of the OEM rotor specs, but they are usually stamped on the rotor its self.
  4. Aug 8, 2009 at 9:26 AM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Per 2008 repair manual: 28.0mm thickness, 26.0mm minimum thickness. Sounds like you don't have to replace your rotors if you measured correctly but you should defenitaly have your rotors resurfaced to prevent any possible brake vibration or squeaking
  5. Aug 8, 2009 at 12:30 PM
    gavonder
    Bethel, Ct
    Thanks for the info. Got it done.
    GA
