2008 Taco Stuck In Park...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mojoe, Apr 22, 2013.
  1. Apr 22, 2013 at 4:45 PM
    mojoe
    mojoe [OP] Member
    Joe
    Scottsdale, AZ
    06 PreRunner
    Edit to ADD: I Goofed on the title... it's a 2006.
    So I've had this issue before that was resolved by following a thread here earlier. It was in fact the STOP 10A fuse that blew. Fast forward to today and I have no clue what the deal is.
    Solutions I've tried so far
    Checked all the fuses, multiple times including:
    10A IG1
    7.5 A ACC
    10A STOP
    10A IG1 No.2
    I've tried pressing the button next to the shifter with zero results.
    I don't have an owner's manual, but will get one very soon, so I do not have anything else to go on besides reading problems people had in the past. At the moment I'm stuck at work trying to find a switch somewhere by the pedal....
    Additional note. I do have an aftermarket tow package.
  2. Apr 22, 2013 at 4:50 PM
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    interesting.
    so that one 10a fuse is ok?
    weird that override button wont work
  3. Apr 22, 2013 at 4:51 PM
    Leoffensive
    Leo
    San Diego, CA
    call the toyota dealer and see if they can suggest something over the phone
  4. Apr 22, 2013 at 5:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If the button isn't working it seems that the shifter linkage is frozen or binding.
  5. Apr 22, 2013 at 5:15 PM
    mojoe
    mojoe [OP] Member
    Joe
    Scottsdale, AZ
    06 PreRunner
    Sounds expensive....
    Yes all lights are operational.
  6. Apr 22, 2013 at 5:24 PM
    mojoe
    mojoe [OP] Member
    Joe
    Scottsdale, AZ
    06 PreRunner
    I have not tried rocking the truck yet. As far as the button pressing, I always have the key in the slot and the truck is turned on and running when I attempt the button push.
    Edit: Tried the rocking....nothing :-(
    I found this thread, but there was no solution posted :-(
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/153019-05-tacoma-stiff-automatic-gear-shifter.html
  7. Apr 22, 2013 at 5:50 PM
    mojoe
    mojoe [OP] Member
    Joe
    Scottsdale, AZ
    06 PreRunner
    yeah the tab is lifted and the button is exposed.
    Side Note... If I push really hard it goes into gear BUT there is a very loud thud.
  8. Apr 22, 2013 at 5:57 PM
    169.254.255.201 Well-Known Member
    Interwebs
    What were you doing in a park?? Pretty sure those are only for walkers. .:D
    Had to.
    Do you hear anything underneath when you try to shift? Well have someone else shift.
  9. Apr 22, 2013 at 7:25 PM
    mojoe
    mojoe [OP] Member
    Joe
    Scottsdale, AZ
    06 PreRunner
    Thank you guys so much for the input. I applied brute force to get the Tacoma in Drive and noticed a thud coming from the shifter area. I was able to drive the truck the whole way home without a problem.
    So my line of thinking right now is that there is something blocking the shifter from making the transition from park. Evidence so far supports that; No blown fuses, No slippage in transmission and I hear a faint click in the shifter area when brake is applied - so that must mean something is disengaging.
    So I followed the awesome tutorial here: Center Console Removal
    Here is a pic from the shifter area. Note: The flash made it look disgusting...sorry. But it does look like some rubbing is occurring when the shifter is being engaged.
    Any further suggestions would be greatly appreciated.
  10. Apr 22, 2013 at 7:30 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    Run over anything? check the linkage to the tranny? When my 06 wouldnt shift out of park it was the brake switch but pressing the button got me out of park.
  11. Apr 22, 2013 at 9:40 PM
    mojoe
    mojoe [OP] Member
    Joe
    Scottsdale, AZ
    06 PreRunner
    Everything right now points to Shift Interlock Solenoid. I'm currently trying to find whats involved with it's replacement.
  12. Apr 23, 2013 at 11:06 AM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    sounds like the solenoid wasn't working and then you finished it off with a bang.
  13. Apr 23, 2013 at 2:53 PM
    mojoe
    mojoe [OP] Member
    Joe
    Scottsdale, AZ
    06 PreRunner
    So I've been calling around and shops want $300+ for the shift interlock solenoid part :-( The guy did say if the override doesn't work then there's another culprit. Of all the places I called everybody seemed surprised it was a "possible" solenoid because they never EVER had to replace one.
    I have a brake light switch on order for pickup tomorrow...
  14. Apr 24, 2013 at 1:14 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    When you pressed the brake and heard the click, the click was the solenoid unlocking the shifter. IMO that takes the solenoid and the brake switch out of it.
  15. Apr 24, 2013 at 6:15 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    get one out of a junk yard $10, i'm sure the 2nd gens are all the same.
  16. Apr 25, 2013 at 1:04 PM
    mojoe
    mojoe [OP] Member
    Joe
    Scottsdale, AZ
    06 PreRunner
    Woke up this morning and it was working fine. I'm gonna make a trip to the junkyard soon and get myself a different shifter unit.
