2008 Tacoma clutch pedal problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimanctil, Nov 30, 2011.
  1. Nov 30, 2011 at 4:44 PM
    jimanctil
    jimanctil [OP] New Member
    2008 Tacoma 4 cylinder 2.7
    My 2008 clutch pedal pushes to the floor and stays there. I can pull it up manually. Now the pedal has no pressure in it at all. I push it in about a inch with my hand and it will go right to the floor. Nothing is engaging. I just got a ride home and it is stuck at a store parking lot right now. A quick google seems like it might be a bad clutch slave cylinder but i am no mechanic. Any help would be appreciated.
    Thanks
    JIm
  2. Nov 30, 2011 at 7:41 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    The springs in the clutch itself are what push the pedal up, via the hydraulic line.
    Any fluid pooled under the truck? Watch out, it uses the same reservoir as the brakes, so check that fluid level. If it goes way down you may have to bleed the brakes too.
    Could be master cylinder, slave cylinder, or a ruptured line IMO.
  3. Nov 30, 2011 at 9:19 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    When my clutch pedal on my 08 stuck to the floor, it was because the small plastic cup that holds the clevis rod we all turn to adjust to get rid of the creaking noise shattered & the clevis rod was laying on the floor. If that rod is missing or out of the plastic cup the pedal will stay on the floor u til you manually pull it up. Just another thing to check.
  4. Nov 30, 2011 at 10:49 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    I have had that problem caused by a bad slave cylinder before
