2008 Tacoma Key fob
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Iz77, Aug 15, 2019.
  1. Aug 15, 2019 at 6:51 AM
    Iz77
    Iz77 [OP] New Member
    Iz
    2008 Tacoma V6 4.2L 4x4 All Black
    2.5 Bilstein lift
    My OEM key fob went out a few years ago and I replaced it with one from Amazon but did not last too long. Can anyone recommend a good one that is not from the dealer? Thanks
  2. Sep 2, 2022 at 12:49 PM
    Csay7805
    Csay7805 Member
    2005 Tacoma SR5 TRD 4x4 Sport
    Working on it!
    Bump!
  3. Sep 2, 2022 at 3:05 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    I bought this set on Ebay last year, programmed up using the "chicken dance" method without issue. Can't say they've seen heavy use in that time, tho.
    Csay7805 likes this.
  4. Sep 6, 2022 at 6:01 PM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    https://www.ajtdesign-llc.com/online-store/Fob-Case-c69686002 As soon as I found these, I bought one! The screw back is more secure, unless you strip the plastic threads, and the design has a special place in the back that supports the CR2032 battery and its board bracket. Barcelona Red has the high-end version with red anodized screws. The squared off edges make it easier to locate in deep pockets.
    9-22 I broke down and ordered a second fob case for the master and spare (and a set of four climate control knobs (black with red anodized screws) for Barcelona Red.
  5. Sep 23, 2022 at 3:02 PM
    Csay7805
    Csay7805 Member
    Working on it!
    Why is my FOB intermittently working? Super finicky! 2005 TRD. Yes the batteries are new in the FOB.
    Seems to lock more than unlock.
  6. Sep 24, 2022 at 7:36 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Have you ever cleaned the surfaces where the button meets the circuit board? After 17 years in pockets, there’s probably some “schmutz” on them.
  7. Oct 10, 2022 at 11:26 AM
    Csay7805
    Csay7805 Member
    Working on it!
    I will try that!
  8. Oct 10, 2022 at 7:52 PM
    Norcal06Taco
    Norcal06Taco Member
    2006 Silver Tacoma TRD 4X4 DCSB
    Rigid backup lights on trigger and manual switch
    I had both of my fobs act up on me on my 06 DCSB trd off road. for me it was the solder points on the green board had broke and would occasionally fall back into place and work properly for the lock button. (unlock worked fine so it was frustrating)
    I got replacements on Amazon and programmed them the first try without fail. they have been working for going on 5 months without even a single issue.
    https://www.amazon.com/gp/product/B06XRK62CT?ie=UTF8
    worth every penny.
    TnShooter likes this.
  9. Oct 11, 2022 at 12:51 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    I have an 06 and upgraded to this switchblade vw style unit. Just cut the key, transfer the circuit board and cut open the old key and take out the transponder and glue it into the designated spot in the new case. Works great. Amazon.com: 3 Buttons Keyless Entry Replacement Key Fob Cover Case Fit for Toyota Highlander Sequoia Sienna Tacoma Tundra Key Fob Shell : Automotive
  10. Oct 11, 2022 at 11:52 AM
    Icarus II
    Icarus II Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    I ditched my fob 3 years ago. Too much bulk in a pocket.
    wingspar likes this.
  11. Oct 15, 2022 at 11:46 AM
    Charlie Bravo
    Charlie
    Just received a postcard from Batteries Plus. They sell and cut new keys, and presntly have a 50% discount on programming keys and fobs.
