2008 tacoma lunging problems
Discussion in 'New Members' started by FRENCH, Aug 18, 2009.
  1. Aug 18, 2009 at 8:04 PM
    FRENCH
    FRENCH [OP] Member
    VIRGINIA
    08 PRERUNNER
    SIDE RAILS AND HARD SHELL BED COVER
    08 tacoma lunging problems, ie: from neutral to drive, the truck hesitates for about 2-3 seconds, and then lunges forward. first time this happened, i nearly ran into someone's trunk!!! dealer says it's normal...
  2. Aug 18, 2009 at 8:06 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    more info please but my guess is its probably when the AC kicks on
  3. Aug 18, 2009 at 8:36 PM
    DanGer
    Do you keep your foot on the brake?
  4. Aug 18, 2009 at 8:37 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Is your A/C on?
  5. Aug 18, 2009 at 8:37 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
  6. Aug 18, 2009 at 8:38 PM
    Uhaul-n-azz
    Uhaul-n-azz Well-Known Member
    fayetteville,AR
    4Runner Stock
  7. Aug 18, 2009 at 10:43 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Mine does it with or without the AC on. It is "normal."
  8. Aug 19, 2009 at 6:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Totally normal.... and even without the A/C on.
    I'm a firm believer that its the transmission downshifting and the rpm's go up.
    I had a Grand Cherokee that did the same thing.
    Use the search button - it's often called the LURCH
