2008 Tundra 1GRFE V6 Engine Dead at 98k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ggms16, Aug 2, 2012.
  1. Aug 15, 2012 at 9:05 PM
    #181
    ggms16
    ggms16 [OP] Well-Known Member
    Tomorrow the engine will be fitted in the tundra..
    How?
    We will use the tundras exhaust manifold in the tacoma heads, blocking the air valves in the manifolds. Leaving disconnected the sensors and try turning the thing on.
    I will make sure ya'll know the results tomorrow.
    I will have the tundra's heads fixed soon, if this will cause too many problems I will stick the tundra's heads back to the truck and that's it.
    Tacoma ECU wouldn't work, not only because the wiring is different, but because some wires are not long enough... Tested. The tundra is just a bit larger in the engine bay.
  2. Aug 15, 2012 at 9:16 PM
    #182
    ggms16
    I'm not so sure about this unless I find how to communicate the air flow with the exhaust manifold in the inside, because the area where the heads meet the exhaust is bigger in the tundra.
  3. Aug 15, 2012 at 10:01 PM
    #183
    Bfry86
    Bfry86 Well-Known Member
    Brandon
    Floyds Knobs, Indiana
    2017 DCLB TRD Sport 4X4
    I hate to hear about these issues given I just bought my 4.0 taco last week and in large part because of its reliability. My dad has put 200k plus on two LandCrusiers( straight6 and V8) and 150k on a v8 Tundra. I know I jumped in late on this thread but I would have to say this is previous owner negligence.. and I'm not sure you can correct it. I'm sorry to hear about this, and hope you have luck with the new engine. Don't write off those Toyota's just yet.. I've seen some great things..
  4. Aug 16, 2012 at 6:47 AM
    #184
    ggms16
    I would just suggest to open a valve cover and see what you have in your used engine. It's extremely easy in these trucks, and as the gasket is rubber, you won't have to change it. If you see sludge, you have time to fix it.. That's what I should have done when I bought it.
  5. Aug 16, 2012 at 7:01 AM
    #185
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    One thing you can try is using snake camera
  6. Aug 16, 2012 at 4:42 PM
    #186
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Don't say snake light! It is a borescope.
  7. Aug 16, 2012 at 5:31 PM
    #187
    BlueT
    NorthEast
  8. Aug 16, 2012 at 8:31 PM
    #188
    Bfry86
    Brandon
    I got mine under 30k miles with all the records and a 100k BTB warrentee... Hopefully, I shouldn't have to worry but I might as well have a look.
  9. Aug 16, 2012 at 8:56 PM
    #189
    ggms16
    Giving a look won't hurt.. It's easy and will give you peace of mind...
    I still regret every second I didn't do that before, because it's not only what the engine and labor costs, time waisted and trips to the mechanic, but the issues retrofitting it what's driving me crazy!
  10. Aug 17, 2012 at 12:28 PM
    #190
    jdchmiel
    jdchmiel Member
    1grfe into mr2
    Are you using a grinder to connect the air injection port to the exhaust port on the manifold?
  11. Aug 17, 2012 at 5:22 PM
    #191
    ggms16
    Guys the job is done.
    The tundra's exhaust manifold was used in the tacoma's engine. Secondary air injection valves were closed properly.
    Installed the engine, turned the key and it ran...
    It ran just perfectly... There were no surprises, everything fitted and worked. I will see how it behaves in the next few days.
    Thank you everyone for your help.
    JSX likes this.
  12. Aug 17, 2012 at 6:50 PM
    #192
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    :yay::yay::woot::woot::thumbsup::thumbsup::woot::woot::yay::yay:
  13. Aug 18, 2012 at 7:55 AM
    #193
    ggms16
  14. Aug 18, 2012 at 8:00 AM
    #194
    Toyota Tech31
    Debary, Florida
    Just happy everything worked out, so far at least...
  15. Aug 18, 2012 at 1:08 PM
    #195
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Big +1 there.
    Sucks to have had the problem in the first place, but we all learned something in the process.
  16. Aug 18, 2012 at 2:29 PM
    #196
    BlueT
    NorthEast
    hey can you do a nice photo of your cluster? Is that transmission temp under the RPMs ? Do you have oil pressure gauge ?
  17. Aug 18, 2012 at 3:41 PM
    #197
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Good deal!
    Glad it all worked out. You going to keep it?
  18. Aug 18, 2012 at 7:15 PM
    #198
    ggms16
    I don't know if I will keep it...
    Last few days I've paid more attention to the Tacoma's and damn, some mods make the truck look so nice...
    I'll maybe trade this big thing for a taco..
    Drove 300miles today, perfect... It feels stronger than before, absolutely nothing seems to be wrong.
  19. Aug 18, 2012 at 7:15 PM
    #199
    ggms16
    I'll do the photo tomorrow. Yes, I do have the oil pressure gauge.
  20. Aug 18, 2012 at 7:16 PM
    #200
    ggms16
    I hope this info helps someone else in a similar situation...
    Thanks Rich
