2008 Tundra 1GRFE V6 Engine Dead at 98k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ggms16, Aug 2, 2012.
  1. Nov 29, 2012 at 12:35 PM
    #241
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I would bring it to dealer and ask them to do oil pressure test. It will show immediately if you have the same problem.
  2. Nov 29, 2012 at 12:41 PM
    #242
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    You are probably just hearing the secondary air injection pumps running when you first start the truck.
  3. Nov 29, 2012 at 2:40 PM
    #243
    mclovin
    mclovin chicka chicka, yeah!
    Biloxi
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    bluet - yeah i just might, i just recently had it serviced. not the same delearship i go to either...
    toyotatech31 - i will keep that in mind. i will check it when i drive home today... hopefully its not there. just kind of weird that out of no where it started up...
  4. Nov 29, 2012 at 3:58 PM
    #244
    BlueT
    NorthEast
    I would not worry much. Unless for some reason you needed crankbolt removed it should be good. Those airpumps do make wierd noise so thats probably what you hearing. I wish Toyota had installed oil pressure gauge on those trucks.
  5. Nov 29, 2012 at 4:02 PM
    #245
    mclovin
    Biloxi
    oh i know, that air pump is kind of crazy. i do know that the sound i heard at lunch was not the pump. the pump only lasts too for about a min after start up. i had a distinct knock that sounded more prevalent from the driver side. i guess im going to keep an eye on it and see how it goes. i know its probably not the best to "wait and see" but screw it... if it blows... i have all the service reports and the truck is less then a year old....
  6. Nov 29, 2012 at 4:06 PM
    #246
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    No need for seafoam. Just change your oil every 3 months on calendar schedule rather than milage, like I do.
  7. Jun 13, 2013 at 11:53 AM
    #247
    miacevedo
    miacevedo Well-Known Member
    SoCal
    SuperWhite 4X4
    All Pro Hybrid front bumper. All Pro rock sliders. Warn Winch. Icon 2.5 Remote Resi Coilovers & Rear Icon 2.0 Extended Remote Resi's. AP Standard leafs. Rear SuperBumps. OEM bed mat and All Weather floor mats. Pelfreybilt IFS Skid. Method NV wheels on 285/75/16 Toyo Open Country AT2.
    So I was searching Google about the differences in the exhaust manifolds from 2005-2011 and 2012-13... the new manifolds have the same ports as this Tundra did.
    Question is: Would I be able to run exhaust manifolds from a 2012-13 Tacoma in a 2006 Tacoma? If my head does not have the holes for the ports, but my manifold does... would there be any issues?
  8. Jun 13, 2013 at 5:30 PM
    #248
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not compatible.
  9. Jun 13, 2013 at 7:31 PM
    #249
    miacevedo
    SoCal
    SuperWhite 4X4
    Why wouldn't it be compatible?
    This guy is running the Taco motor, with the Tundra manifolds... only problem is his computer throwing a CEL because the air valves are not working. If he didn't have the extra air valves on the Tundra to begin with, wouldn't it be fine?
  10. Jun 13, 2013 at 10:14 PM
    #250
    Rich91710
    Rich
    Los Angeles
    08 Base
    If the manifold is designed for the ports on the Tundra head, then it is going to lack the external ports that tie into the earlier emissions system.
  11. Jul 4, 2013 at 5:50 PM
    #251
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Information for those who might be interested if you suspect a dirty engine. Sludge engine clean up - 1 pt of Dextron Trans Fluid added to oil. Run for 500 miles. Change oil. Trans Fluid oil has a lot of cleaner in it.
